Home » Eclipse Projects » Eclipse Platform » Any way to "reduce" a "jar-URL" to an actual path?
Any way to "reduce" a "jar-URL" to an actual path? [message #329359] Fri, 20 June 2008 17:18 Go to next message
R3.3; WinXP
We have a clunky old 3rd-party bit of code to which we must supply, in
the form of Windows full-paths, concatenated with ";", the actual
class-paths of all code and jars in some set. Thanks to an earlier post
("How to compute classpath from bundle?") by Jeff Pilgrim (whose email
address is no longer valid, alas), I have some code that will extract
from the Platform and the Bundle API a collection of URL's. So far so
good. Here is an example list:
jar:file:C:\<my-Eclipse-install>\eclipse\plugins\org.eclipse.ui_3.3.0.I20070614-0800.jar!/
jar:file:C:\<my-Eclipse-install>\eclipse\plugins\org.eclipse.swt_3.3.0.v3346.jar!/
jar:file:C:\<my-Eclipse-install> \eclipse\plugins\org.eclipse.jface_3.3.0.I20070606-0010.jar! /
jar:file:C:\<my-Eclipse-install> \eclipse\plugins\org.eclipse.core.commands_3.3.0.I20070605-0 010.jar!/
where I have printed the URL values using URL.toString().
The problem is -- how to convert such a "jar-URL" to a string? Our
clunky old 3rd-party code would want the list to look like this:
C:\<my-Eclipse-install>\eclipse\plugins\org.eclipse.jface_3.3.0.I20070606-0010.jar
Now, I can (and probably soon will have to) build my own little parser,
whose input would be URL.toString(), but that's of course fragile and
bug-prone.
I'd prefer it if there were a Platform of FileLocator method that took
as input one of the URL's and gave me the desired String as output. But
FileLocator.resolve(URL) simply does not work (it does other nice
things), and in fact the URL's above are *ALREADY* the output of
FileLocator.resolve(). I've also tried FileLocator.toFileURL(), which
seems to simply return the same URL, in this case.
So what is to be done?
TIA,
Paul
Re: Any way to "reduce" a "jar-URL" to an actual path? [message #329404 is a reply to message #329359] Mon, 23 June 2008 08:43 Go to previous messageGo to next message
"Paul Th. Keyser" <rolarenfan@earthlink.net> writes:
Converting to a String is not the problem, what you are aiming for is
an absolute file path (as a string).
The jar: form of URL is a Java thing, not specific to Eclipse. You
probably should look at the documentation for
java.net.JarURLConnection and take it from there.
Owen Rees; speaking personally, and not on behalf of HP.
Hewlett-Packard Limited. Registered No: 690597 England
Registered Office: Cain Road, Bracknell, Berks RG12 1HN
Re: Any way to "reduce" a "jar-URL" to an actual path? [message #329423 is a reply to message #329359] Mon, 23 June 2008 13:33 Go to previous messageGo to next message
FileLocator.toFileURL(*) is the method that should be used in your case.
It will convert any platform: URLs into file: URLs ... it might be
that passing in the jar: URLs is confusing it, and they should be the
platform: URLs
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: Any way to "reduce" a "jar-URL" to an actual path? [message #329428 is a reply to message #329423] Mon, 23 June 2008 17:12 Go to previous messageGo to next message
Paul,
Isn't there a danger that the jar will be unzipped when that might not
be a desired side-effect? Of course you're right that if it has
platform: or bundleentry: you'd need a more general approach...
> case. It will convert any platform: URLs into file: URLs ... it might
> be that passing in the jar: URLs is confusing it, and they should be
> the platform: URLs
> PW
Re: Any way to "reduce" a "jar-URL" to an actual path? [message #329435 is a reply to message #329404] Tue, 24 June 2008 05:01 Go to previous messageGo to next message
Right, as you say, String per se is not the problem (e.g., toString()
gets me a String), and what I want is that absolute-file-path.
Glad to know that the "jar:"-URL is standard Java; & thanks for the
pointer to
http://java.sun.com/javase/6/docs/api/java/net/JarURLConnect ion.html
which I did not know about; those docs emphasize that the 3rd-party code
we are struggling with is truly clunky, since JarURLConnection seems to
be intended to be used to work with the jar without having to "reduce"
to an absolute file-path.
-Paul
Re: Any way to "reduce" a "jar-URL" to an actual path? [message #329436 is a reply to message #329428] Tue, 24 June 2008 05:12 Go to previous message
Ed Merks wrote:
> Paul,
>> the platform: URLs
>> PW
Well, I started with what I took to be a platform URL (obtained from
"ManifestElement"), and used FileLocator.resolve(), which gave me the
"jar:"-URL's; if I try toFileURL(), I get as follows:
bundleentry://78/
mapped by FileLocator.resolve() =>
jar:file:C:\<my-eclipse-install>\eclipse\plugins\org.eclipse.ui_3.3.0.I20070614-0800.jar!/
mapped by FileLocator.toFileURL() =>
file:/C:/<my-eclipse-install> /eclipse/workspace/.metadata/.plugins/org.eclipse.pde.core/u dat.product/org.eclipse.osgi/bundles/78/1/.cp/
So it looks to me like the toFileURL() is unzipping (or anyway copying)
the jar into a sort of work-area defined and used by Eclipse.
-Paul
Previous Topic:Setting content types on a per-project basis
Next Topic:New plugin for Run>Run...
Current Time: Wed Nov 19 01:59:33 EST 2025
Powered by FUDForum. Page generated in 0.04636 seconds
