Home » Eclipse Projects » Eclipse Platform » [Databinding] Converted values not seen in Text
[Databinding] Converted values not seen in Text [message #329295] |
Wed, 18 June 2008 10:32  |
I am using Eclipse 3.4RC3.
I have a Text field, which is connected to a String property via data
binding like this:
IObservable observable = ... ; // bound to my String property
Text name=new Text(parent, SWT.NONE);
UpdateValueStrategy targetToModelStrategy=new UpdateValueStrategy();
targetToModelStrategy.setConverter(new TrimWhiteSpaceConverter());
IObservableValue textObserveWidget=SWTObservables.observeText(name,
SWT.FocusOut);
dataBindingContext.bindValue(textObserveWidget, observable,
targetToModelStrategy, null);
This should trim whitespace (leading and trailing) from the value
entered into the Text field.
Now, this works fine for updating the model, when I enter " Test " into
the Text field, the model gets updated with "Test" (note: whitespace
removed).
What does not work: the value in the Text field stays " Test ".
There must be a simple way to make the Text field also be updated with
the value after conversion. Can anyone point me in the right direction?
Christoph Jäger
Re: [Databinding] Converted values not seen in Text [message #329298 is a reply to message #329295] |
Wed, 18 June 2008 10:59   |
You'll need to call do this manually after your model is updated by calling:
Binding#updateModelToTarget()
Tom
Christoph Jaeger schrieb:
> binding like this:
> SWT.FocusOut);
> removed).
> Christoph Jäger
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: [Databinding] Converted values not seen in Text [message #329438 is a reply to message #329406] |
Tue, 24 June 2008 06:03  |
Filed an enhancement request 238222
https://bugs.eclipse.org/bugs/show_bug.cgi?id=238222
Christoph
Eric Rizzo wrote:
> Boris Bokowski wrote:
>> Could you please file an enhancement request in Bugzilla? This seems
>> to be a common feature request that we should support. We could also
>> use the Bugzilla to discuss possible workarounds.
> Please post the Bugzilla number or link here so other interested readers
> can follow the progress.
> Eric
>> "Christoph Jaeger" <christoph.jaeger@cargodata.at> wrote in message
>> news:g3b9dr$pm7$1@build.eclipse.org...
>>>> calling:
>>> Thanks for your hint. So I extended UpdateValueStrategy to override
>>> @Override
>>> protected IStatus doSet(IObservableValue observableValue, Object value)
>>> IStatus status=super.doSet(observableValue, value);
>>> if (binding!=null) binding.updateModelToTarget();
>>> return status;
>>> and make sure I set the binding (see last line):
>>> UpdateValueStrategyWithFeedback targetToModelStrategy=new
>>> UpdateValueStrategyWithFeedback();
>>> Binding binding=dataBindingContext.bindValue(textObserveWidget,
>>> observable, targetToModelStrategy, null);
>>> targetToModelStrategy.setBinding(binding);
>>> Looks a bit strange (first I use the targetModelStrategy to create a
>>> binding, and then I feed the resulting binding to the
>>> targetModelStrategy), but seems to work. Do I need to worry about
>>> disposing the binding instance I pass into targetModelStrategy?
>>> Or is there an easier way to achieve the same?
>>> Thanks,
>>> Christoph
Current Time: Thu Jul 24 23:56:00 EDT 2025
Powered by FUDForum. Page generated in 0.07396 seconds
