Home » Eclipse Projects » Eclipse Platform » [Databinding] Converted values not seen in Text
[Databinding] Converted values not seen in Text [message #329295] Wed, 18 June 2008 10:32 Go to next message
I am using Eclipse 3.4RC3.
I have a Text field, which is connected to a String property via data
binding like this:
IObservable observable = ... ; // bound to my String property
Text name=new Text(parent, SWT.NONE);
UpdateValueStrategy targetToModelStrategy=new UpdateValueStrategy();
targetToModelStrategy.setConverter(new TrimWhiteSpaceConverter());
IObservableValue textObserveWidget=SWTObservables.observeText(name,
SWT.FocusOut);
dataBindingContext.bindValue(textObserveWidget, observable,
targetToModelStrategy, null);
This should trim whitespace (leading and trailing) from the value
entered into the Text field.
Now, this works fine for updating the model, when I enter " Test " into
the Text field, the model gets updated with "Test" (note: whitespace
removed).
What does not work: the value in the Text field stays " Test ".
There must be a simple way to make the Text field also be updated with
the value after conversion. Can anyone point me in the right direction?
Christoph Jäger
Re: [Databinding] Converted values not seen in Text [message #329298 is a reply to message #329295] Wed, 18 June 2008 10:59 Go to previous messageGo to next message
You'll need to call do this manually after your model is updated by calling:
Binding#updateModelToTarget()
Tom
Christoph Jaeger schrieb:
> binding like this:
> SWT.FocusOut);
> removed).
> Christoph Jäger
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: [Databinding] Converted values not seen in Text [message #329302 is a reply to message #329298] Wed, 18 June 2008 11:25 Go to previous messageGo to next message
> calling:
Thanks for your hint. So I extended UpdateValueStrategy to override
protected IStatus doSet(IObservableValue observableValue, Object value)
IStatus status=super.doSet(observableValue, value);
if (binding!=null) binding.updateModelToTarget();
return status;
and make sure I set the binding (see last line):
UpdateValueStrategyWithFeedback targetToModelStrategy=new
UpdateValueStrategyWithFeedback();
Binding binding=dataBindingContext.bindValue(textObserveWidget,
observable, targetToModelStrategy, null);
targetToModelStrategy.setBinding(binding);
Looks a bit strange (first I use the targetModelStrategy to create a
binding, and then I feed the resulting binding to the
targetModelStrategy), but seems to work. Do I need to worry about
disposing the binding instance I pass into targetModelStrategy?
Or is there an easier way to achieve the same?
Christoph
Re: [Databinding] Converted values not seen in Text [message #329365 is a reply to message #329302] Sat, 21 June 2008 06:35 Go to previous messageGo to next message
Could you please file an enhancement request in Bugzilla? This seems to be a
common feature request that we should support. We could also use the
Bugzilla to discuss possible workarounds.
Boris
"Christoph Jaeger" <christoph.jaeger@cargodata.at> wrote in message
news:g3b9dr$pm7$1@build.eclipse.org...
>> calling:
> @Override
> return status;
> Christoph
Re: [Databinding] Converted values not seen in Text [message #329406 is a reply to message #329365] Mon, 23 June 2008 08:58 Go to previous messageGo to next message
Please post the Bugzilla number or link here so other interested readers
can follow the progress.
Eric
>>> calling:
>> @Override
>> return status;
>> Thanks,
>> Christoph
Re: [Databinding] Converted values not seen in Text [message #329438 is a reply to message #329406] Tue, 24 June 2008 06:03 Go to previous message
Filed an enhancement request 238222
https://bugs.eclipse.org/bugs/show_bug.cgi?id=238222
Christoph
>> to be a common feature request that we should support. We could also
>> use the Bugzilla to discuss possible workarounds.
> Eric
>>>> calling:
>>> @Override
>>> return status;
>>> Thanks,
>>> Christoph
Previous Topic:New plugin for Run>Run...
Next Topic:i feel overwhelmled!!!
Current Time: Thu Nov 06 11:07:43 EST 2025
Powered by FUDForum. Page generated in 0.03967 seconds
