| Using Common Navigator Framework for EMF objects browsing [message #329277] |
Wed, 18 June 2008 04:19  |
I just started to move my EMF Object Browser to CNF, basing on Michael
Elder's presentation and articles. I've added filter to add only projects
of our nature and all model structure as EObject entries. It looks (and
works) fine, but I did not find answers for some questions:
1. How can I add "Workspace" entry as a parent for "Project" entries?
2. Can (and how) I use EObject "Application" entry instead of IProject
resource
entry or, backwards, I have to browse only IResource entries?
3. If it should be IResource entries and IProject entry has to be the
"base" entry, how can I remove all "obsolete" popup menu actions (for
example - use my "Delete" and "Rename" instead of standard, remove Run,
Debug and PDE Tools action groups and so on)?
4. How can I connect my EObject entries to ClearCase and add all proper
actions?
Thanks in advance,
Yury
| Re: Using Common Navigator Framework for EMF objects browsing [message #329300 is a reply to message #329277] |
Wed, 18 June 2008 11:16   |
Hi Yury,
I answer your questions below, you also might want to look at the
current 3.4RC4 build, there is some new documentation about the CNF (in
the Platform Plugin Developers Guide) what might help you to better
understand the principals.
Francis
> projects of our nature and all model structure as EObject entries. It
> looks (and works) fine, but I did not find answers for some questions:
I'm not sure what you intend by this. The workspace resource
(IWorkspace) is in fact the root of the tree for the CN when it is used
with resources. Can you explain further what you are interested in?
> resource
As far as which object is actually in the CommonViewer, if you are using
resources it should be the IProject. However, you can make a content
provider (ITreeContentProvider) that looks up the corresponding EObject
application entry and does what you want with that.
In your viewer action binding you are probably including all of the
actions from org.eclipse.ui.resources. You can be more selective about
which of these actions you include and if you want your own, replace
when with your own implementation. Look at the code in the
org.eclipse.ui.navigator resources plugin for how these are implemented.
> actions?
This is an issue for the Team support. I'm not that familiar with the
details of how that works (you should be able to just get the Team
actions from the CN by using the standard resource actions described
above) -- how the Team support is hooked to ClearCase I don't know. I
suggest you look at the Team support documentation.
> Thanks in advance,
> Yury
http://dev.eclipse.org/blogs/francis
http://wiki.eclipse.org/Common_Navigator_Framework
http://wiki.eclipse.org/Common_Navigator_Framework_Use_Cases
You have brains in your head.
You have feet in your shoes.
- Dr Seuss, Oh the Places You'll Go
FUDForum. Page generated in 0.40174 seconds
