special Jface dialog [message #329230] |
Mon, 16 June 2008 19:03  |
Hello All,
Goal: Create a JFace dialog with a SWT text widget and the okay and cancel
buttons such that when the user types text, the dialog and the text area
expand/shrink according to the width and height of the text.
private Text textArea;
I am using a gridlayout:
textArea.setLayoutData(new GridData(GridData.FILL_BOTH));
I can get the textarea to expand/shrink using the following code:
textArea.setSize(textArea.computeSize(SWT.DEFAULT, SWT.DEFAULT));
I have put this code in the modify event of the textarea. But I think
there might be a better place to put this. Any ideas?
I could not find a way to shrink/expand the dialog. The only place where I
can set the size of the dialog is in the configureShell(Shell shell)
function. But this sets the size only once when creating the dialog.
I also tried to do the following in the createContents(composite parent)
function:
getShell().setSize(getShell().computeSize(SWT.DEFAULT, SWT.DEFAULT));
this also sets the size once. How do I resize the dialog and keep it in
sync with the textarea. It is better in this case to use just a shell? and
not a JFace dialog?
Thanks.
FUDForum. Page generated in 0.04136 seconds
