Home » Eclipse Projects » Eclipse Platform » How to get IAction from actionSet?
How to get IAction from actionSet? [message #329167] Mon, 16 June 2008 06:22 Go to next message
I've developed plugin with extension point org.eclipse.ui.actionSet. It
has class that implements IWorkbenchWindowActionDelegate. How to get
IAction in the constructor of this class?
Re: How to get IAction from actionSet? [message #329172 is a reply to message #329167] Mon, 16 June 2008 08:09 Go to previous message
You can't ... but if you implement IActionDelegate2 as well you will
have your init(*) method called shortly after construction.
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Previous Topic:extension points distribution
Next Topic:calling tree during execution
Current Time: Tue Dec 02 22:23:40 EST 2025
Powered by FUDForum. Page generated in 0.05686 seconds
