Home » Eclipse Projects » Eclipse Platform » New Common Navigator Framework blog
New Common Navigator Framework blog [message #329146] Fri, 13 June 2008 13:58
I am a new committer in the Platform UI project and I'm working on the
Common Navigator Framework. If you are interested in this, please have
a look at my blog:
http://dev.eclipse.org/blogs/francis
One good way to get interesting Eclipse blogs is to use the Planet
Eclipse aggregator which is here:
http://planeteclipse.org/planet/
I would love to hear from you by commenting the blog, or if you have
Common Navigator use cases, please put them here:
http://wiki.eclipse.org/Common_Navigator_Framework_Use_Cases
Finally, if you have Common Navigator issues and questions for the
newsgroups, please put CommonNavigator in the title of your post and I
will try to address them quickly.
I look forward to working with the community on improving the Common
Navigator.
Francis
Previous Topic:Where is the list of the now-exist PropertyTesters?
Next Topic:Run as ... issue
Current Time: Fri Nov 07 17:29:39 EST 2025
Powered by FUDForum. Page generated in 0.03195 seconds
