Home » Eclipse Projects » Eclipse Platform » Dynamic icons from file system in plugin
Dynamic icons from file system in plugin [message #329122] Fri, 13 June 2008 05:23 Go to next message
Can a plugin load icons/images from a URL such as
"file:///c:/myicon.gif" ? The URL.openStream() fails in PDE with an
UnkownHostException. The same code works in a simple, not plugin, java
program.
Any idea ?
Loïc
Re: Dynamic icons from file system in plugin [message #329126 is a reply to message #329122] Fri, 13 June 2008 07:32 Go to previous messageGo to next message
Loïc,
What you describe sounds like a really bad idea even if it works. What
does the stack trace look like? If it's a failure in the
URL.openStream itself I kind of doubt it's an Eclipse issue but more
fundamental. I suspect that file:/c:/myicon.gif and
file://c:/myicon.gif are likely to work better...
> program.
> Any idea ?
> Loïc
Re: Dynamic icons from file system in plugin [message #329127 is a reply to message #329126] Fri, 13 June 2008 09:28 Go to previous messageGo to next message
I want to integrate another tool with Eclipse. The other provides data,
which contains paths to icons which must be displayed in an Eclipse
TreeViewer.
The correct url should be file://localhost/c:/myicon.gif. In W3C specs,
it is written that localhost can be omitted.
file://c:/myicon.gif works in Firefox, which changes it to
file:///c:/myicon.gif which also works in Firefox.
There is no stack trace because ImageDescriptor.getImageData() fails
silently.
Ed Merks a écrit :
> Loïc,
>> program.
>> Any idea ?
>> Loïc
Re: Dynamic icons from file system in plugin [message #329129 is a reply to message #329127] Fri, 13 June 2008 09:47 Go to previous messageGo to next message
Loïc,
Did you try what I suggested? It's possible to step into the code to
see what's going on... And besides, you said you saw a failure with
leads me to believe the failure wasn't silent and that there will be a
stack trace in your log...
I thought the URI RFC only talked about the // segment representing the
authority... I think different schemes can interpret the information
there how they like....
(Please try to avoid doing a reply-all so I don't get direct notes to my
e-mail address.)
> data, which contains paths to icons which must be displayed in an
> Eclipse TreeViewer.
> specs, it is written that localhost can be omitted.
> silently.
> Ed Merks a écrit :
>> Loïc,
>> What does the stack trace look like? If it's a failure in the
>>> java program.
>>> Any idea ?
>>> Loïc
Re: Dynamic icons from file system in plugin [message #329698 is a reply to message #329129] Tue, 01 July 2008 09:10 Go to previous message
Sorry for my late answer. As usually, you were right, Ed ...
Thanks a lot.
Loïc
Ed Merks a écrit :
> Loïc,
> e-mail address.)
>> Eclipse TreeViewer.
>> silently.
>> Ed Merks a écrit :
>>> Loïc,
>>>> java program.
>>>> Any idea ?
>>>> Loïc
Previous Topic:code template
Next Topic:Are you responsible for providing eclipse at your firm?
Current Time: Fri Nov 14 14:38:20 EST 2025
Powered by FUDForum. Page generated in 0.03928 seconds
