Home » Eclipse Projects » Eclipse Platform » TableColumnLayout and Memento
| TableColumnLayout and Memento [message #329096] |
Thu, 12 June 2008 11:38  |
Hi, therre doesn't appear to be a jface newsgroup so I've posted this
here. Please redirect me if there's somewhere more appropriate to post
this.
I'm interested in using a Memento to preserve the state of a
TableColumnLayout, so that my table is recreated as it was when my view
is closed and reopened. My TableColumnLayout is given ColumnWeightData
for each TableColumn I add, with weight 1, and minimum width 75. If a
column is resized, the ColumnWeightData is changed for ColumnPixelData
internally, and a fixed width is assigned to the column. When saving
the state of my view in a memento, I am unable to retrieve the
ColumnLayoutData for each column - the getLayoutData(Scrollable, int)
method declared on AbstractColumnData has default access. As the
ColumnLayoutData is stored as widget data, I can retrieve it by
'guessing' the key, but I would much rather access it through a public
API. Is there any alternative to this? I've experimented with writing
a listener to record when a column is manually resized (seemed like
overkill as the TableColumnLayout already does this, and deactivates
listeners based on whether or not they were resized by a user or
programmatically), and setting the width and minimum weight of a column
to be the recorded width (column resize behavior is different to having
a mixture of columns sized by weight, and fixed width).
Thanks in advance,
Setwart Francis
| Re: TableColumnLayout and Memento [message #329102 is a reply to message #329096] |
Thu, 12 June 2008 13:44   |
Hm,
Why do you need access to the ColumnLayout? You could simply ask the
column for the width and calculate it your own for relative columns.
Tom
> this.
> Thanks in advance,
> Setwart Francis
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
| Re: TableColumnLayout and Memento [message #329120 is a reply to message #329102] |
Fri, 13 June 2008 05:08   |
Hi, thanks for the response. I'd like to recreate a table so that after
the view is part of is closed and reopened, the column appearance and
behavior is unaffected. Only being able to access the column width, I
can't determine whether it was determined by weight, or an absolute
width has been specified by the user.
Tom Schindl wrote:
> Hm,
> Tom
>> post this.
>> view is closed and reopened. My TableColumnLayout is given
>> ColumnWeightData for each TableColumn I add, with weight 1, and
>> minimum width 75. If a column is resized, the ColumnWeightData is
>> changed for ColumnPixelData internally, and a fixed width is assigned
>> to the column. When saving the state of my view in a memento, I am
>> unable to retrieve the ColumnLayoutData for each column - the
>> getLayoutData(Scrollable, int) method declared on AbstractColumnData
>> has default access. As the ColumnLayoutData is stored as widget data,
>> I can retrieve it by 'guessing' the key, but I would much rather
>> access it through a public API. Is there any alternative to this?
>> I've experimented with writing a listener to record when a column is
>> manually resized (seemed like overkill as the TableColumnLayout
>> already does this, and deactivates listeners based on whether or not
>> they were resized by a user or programmatically), and setting the
>> width and minimum weight of a column to be the recorded width (column
>> resize behavior is different to having a mixture of columns sized by
>> Thanks in advance,
>> Setwart Francis
| Re: TableColumnLayout and Memento [message #329181 is a reply to message #329120] |
Mon, 16 June 2008 10:53   |
Sounds reasonable - can you please file an enhancement request in Bugzilla?
Boris
"Stewart Francis" <stew@owww.org> wrote in message
news:g2tdel$55m$1@build.eclipse.org...
> can't determine whether it was determined by weight, or an absolute width
> Tom Schindl wrote:
>> Hm,
>> Tom
>>> this.
>>> Thanks in advance,
>>> Setwart Francis
| Re: TableColumnLayout and Memento [message #329415 is a reply to message #329181] |
Mon, 23 June 2008 10:55  |
Hi, apologies for the delay in response. I've investigated a little
further and have decided that Mementos are inappropriate for what I want
to achieve - saveState is only called when the workbench is closing the
view, and I'd like to save the state when the user is closing the view
also. I've looked at achieving this with DialogSettings instead of
Mementos, and obviously have the same problem regarding not being able
to access TableColumnLayout internals. However, I feel it would be more
appropriate to have a listener so DialogSettings can be updated to
reflect any changes in the way the column widths are calculated (as
there is no mechanism for getting the state immediately before the view
is closed - either by a user or by the workbench). I'd be interested to
hear your opinions on this.
Stew
> Thanks
> Boris
>> Tom Schindl wrote:
>>> Hm,
>>> Tom
>>>> this.
>>>> Thanks in advance,
>>>> Setwart Francis
Current Time: Mon Dec 01 14:50:25 EST 2025
Powered by FUDForum. Page generated in 0.04760 seconds
