Home » Eclipse Projects » Eclipse Platform » Eclipse does not run with JRE 1.6.0
Eclipse does not run with JRE 1.6.0 [message #329068] Wed, 11 June 2008 19:50 Go to next message
I recently update my version of JRE to the 1.6.0 version.
But then on i canŽt start the eclipse plataform.
This update is made by the JRE it self so is a big problem for allmost
all users of eclipse.
Bye.
Re: Eclipse does not run with JRE 1.6.0 [message #329069 is a reply to message #329068] Wed, 11 June 2008 20:33 Go to previous messageGo to next message
Camilo,
It almost makes you wonder how it could be possible that no one noticed
that Eclipse simply stops working with 1.6.0...
Which OS are you on? Specifically which JRE level/vendor did you update
too? I.e., if you run it with -version, what does it print? Are there
clues in the <workspace>/.metadata/.log?
> Bye.
Re: Eclipse does not run with JRE 1.6.0 [message #329076 is a reply to message #329069] Thu, 12 June 2008 03:21 Go to previous messageGo to next message
I do not have any issue running Eclipse Classic SDK 3.4RC3 on Windows XP
(SP2) with a Java 6 runtime underneath.
java.runtime.name=Java(TM) SE Runtime Environment
java.runtime.version=1.6.0_05-b13
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.6
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.6.0_05
Regards, Uwe
> Camilo Hern
Re: Eclipse does not run with JRE 1.6.0 [message #329085 is a reply to message #329076] Thu, 12 June 2008 06:19 Go to previous messageGo to next message
No issues with sun JDK 1.5 AND 1.6, ubuntu 8.04
Uwe Stieber wrote:
> Regards, Uwe
>>> But then on i can´t start the eclipse plataform.
>>> Bye.
Re: Eclipse does not run with JRE 1.6.0 [message #329093 is a reply to message #329069] Thu, 12 June 2008 10:05 Go to previous message
In case the platform is OSX, see
https://bugs.eclipse.org/bugs/show_bug.cgi?id=216051 (the workaround is to
use a 1.5 jre).
Grant
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:g2pqp9$8vl$1@build.eclipse.org...
> Camilo,
> Camilo Hern
Previous Topic:Custom Perspective
Next Topic:Runtime launch of workbench.
Current Time: Sat Nov 08 01:21:35 EST 2025
Powered by FUDForum. Page generated in 0.03316 seconds
