| Problem loading SelectionView sample plug-in [message #329064] |
Wed, 11 June 2008 12:51  |
Originally posted by: gang.xu.delphi.com
The Article:
http://www.eclipse.org/articles/Article-WorkbenchSelections/ article.html
contains an example plug-in that has the SelectionView class. There were
problems opening the view, so I thought perhaps the project was too old,
and I moved the view class into my own project (version 3.3.2).
Even after adding the view to my plug-in however, I got the following
error message:
"Error creating the view.
redo6_5.views.SelectionView"
Can someone explain what is going on? The extensions panel in the project
clearly shows that the class has been found when "browse" is used.
Here is the full error message for reference (it's quite long, and I
cannot make sense of it beyond the first line). Thanks in advance!
java.lang.ClassNotFoundException: redo6_5.views.SelectionView
at java.lang.ClassLoader.findClass(Unknown Source)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:429)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:369)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:357)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:289)
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1269)
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:160)
org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:788)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugi n.java:252)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
org.eclipse.ui.internal.WorkbenchPlugin.createExtension(Work benchPlugin.java:248)
org.eclipse.ui.internal.registry.ViewDescriptor.createView(V iewDescriptor.java:69)
org.eclipse.ui.internal.ViewReference.createPartHelper(ViewR eference.java:327)
org.eclipse.ui.internal.ViewReference.createPart(ViewReferen ce.java:227)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:592)
org.eclipse.ui.internal.WorkbenchPage$ActivationList.setActi ve(WorkbenchPage.java:4080)
org.eclipse.ui.internal.WorkbenchPage$17.runWithException(Wo rkbenchPage.java:3145)
org.eclipse.ui.internal.StartupThreading$StartupRunnable.run (StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:129)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3659)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3296)
org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:801)
org.eclipse.ui.internal.Workbench$25.runWithException(Workbe nch.java:1342)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2309)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
at org.eclipse.equinox.launcher.Main.main(Main.java:1148)
| Re: Problem loading SelectionView sample plug-in [message #329098 is a reply to message #329064] |
Thu, 12 June 2008 12:05  |
Dan Xu wrote:
> The Article:
> were problems opening the view, so I thought perhaps the project was
> too old, and I moved the view class into my own project (version 3.3.2).
See my answer in the newcomer newsgroup.
Dani
> error message:
> project clearly shows that the class has been found when "browse" is
> used.
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
FUDForum. Page generated in 0.25271 seconds
