Home » Eclipse Projects » Eclipse Platform » customize strings/messages from WorkbenchMessages
customize strings/messages from WorkbenchMessages [message #329049] Wed, 11 June 2008 06:22 Go to next message
I think earlier I posted in wrong group
( http://dev.eclipse.org/newslists/news.eclipse.technology.bab el/msg00080.html)
I want to override/customize certain strings/messages from WorkbenchMessages
But as this is in internal package i.e. org.eclipse.ui.internal
So just wondering is there right way to do it?
Any help will be appreciated.
Thanks.
- Parvez
Re: customize strings/messages from WorkbenchMessages [message #329050 is a reply to message #329049] Wed, 11 June 2008 07:03 Go to previous messageGo to next message
Parvez,
I think you'd need to open the jar and change the *.properties file
with. Translations typically do this by providing *.properties files
that are applicable when in the corresponding locale. Are you looking
to do that, or to change the basic English strings?
PC wrote:
> WorkbenchMessages
> Thanks.
> - Parvez
Re: customize strings/messages from WorkbenchMessages [message #329051 is a reply to message #329050] Wed, 11 June 2008 08:37 Go to previous messageGo to next message
Hi Ed,
Yes, I am looking to change basic English strings which are in
messages.properties under "org.eclipse.ui.internal" package and
WorkbenchMessages class reads it.
In my workspace, I have created a nl fragment for
"org.eclipse.ui.workbench" plugin and other language properties files
(like messages_de.properties) are picked up from it (earlier
Fragment-Host value was wrong), but I am not sure what do for English
strings i.e. messages.properties.
Any suggestions?
Thanks.
- Parvez
Ed Merks wrote:
> Parvez,
> PC wrote:
>> WorkbenchMessages
>> Thanks.
>> - Parvez
Re: customize strings/messages from WorkbenchMessages [message #329082 is a reply to message #329051] Thu, 12 June 2008 04:47 Go to previous messageGo to next message
Still thinking on the line of customizing English strings, I am just
wondering if there is no recommended way at the moment, then is it
possible to have extension point where messages.properties file can be
specified? Something like
http://publib.boulder.ibm.com/infocenter/sametime/v7r5m1/ind ex.jsp?topic=/com.ibm.help.sametime.admin.doc/st_adm_comm_cu stommessage_t.html
Any thoughts/suggestions?
Thanks.
- Parvez
PC wrote:
> Hi Ed,
> Any suggestions?
> Thanks.
> - Parvez
> Ed Merks wrote:
>> Parvez,
>> PC wrote:
>>> Hi,
>>> WorkbenchMessages
>>> Thanks.
>>> - Parvez
Re: customize strings/messages from WorkbenchMessages [message #329086 is a reply to message #329082] Thu, 12 June 2008 06:49 Go to previous messageGo to next message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=236829
> Thanks.
> - Parvez
> PC wrote:
>> Hi Ed,
>> Any suggestions?
>> Thanks.
>> - Parvez
>> Ed Merks wrote:
>>> Parvez,
>>> files that are applicable when in the corresponding locale. Are you
>>> looking to do that, or to change the basic English strings?
>>> PC wrote:
>>>> Hi,
>>>> WorkbenchMessages
>>>> Thanks.
>>>> - Parvez
Re: customize strings/messages from WorkbenchMessages [message #329088 is a reply to message #329082] Thu, 12 June 2008 08:29 Go to previous messageGo to next message
Parvez,
No, the English strings are not designed to be replaced. Imagine
multiple different plugins trying to do that and then all running in one
application: which replacement wins? So opening the jar and changing
the properties seems like the only way to go (other than perhaps faking
a locale and treating the strings you want to replace as translations
for that locale)...
> Thanks.
> - Parvez
> PC wrote:
>> Hi Ed,
>> Any suggestions?
>> Thanks.
>> - Parvez
>> Ed Merks wrote:
>>> Parvez,
>>> PC wrote:
>>>> Hi,
>>>> WorkbenchMessages
>>>> Thanks.
>>>> - Parvez
Re: customize strings/messages from WorkbenchMessages [message #329089 is a reply to message #329088] Thu, 12 June 2008 08:46 Go to previous messageGo to next message
Why faking a locale. The last part of the locale is designed to be
application specific.
messages_de_AT_beso.properties at least it is for ResourceBundle I don't
know how NLS uses this kind of thing.
Tom
Ed Merks schrieb:
> Parvez,
> for that locale)...
>> Thanks.
>> - Parvez
>> PC wrote:
>>> Hi Ed,
>>> Any suggestions?
>>> Thanks.
>>> - Parvez
>>> Ed Merks wrote:
>>>> Parvez,
>>>> PC wrote:
>>>>> Hi,
>>>>> WorkbenchMessages
>>>>> Thanks.
>>>>> - Parvez
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: customize strings/messages from WorkbenchMessages [message #329090 is a reply to message #329089] Thu, 12 June 2008 09:31 Go to previous message
Sometimes a word could have a different meaning in a tool which is
targeted for a specific industry e.g. resource, perspective etc.
Though I see the point that different plugins overriding same thing, but
these scenarios can be applied to any other objects as well.
There were other thoughts:
a. Class can be removed from internal package so that individual can
provide another messages.properties.
b. messages.properties file from user defined nl fragment should be
given preference.
But now I tried messages_en.properties instead of messages.properties in
fragment and it worked.
Thanks Ed and Tom.
Parvez
> Tom
> Ed Merks schrieb:
>> Parvez,
>> one application: which replacement wins? So opening the jar and
>> changing the properties seems like the only way to go (other than
>> perhaps faking a locale and treating the strings you want to replace
>> as translations for that locale)...
>>> be specified? Something like
>>> Thanks.
>>> - Parvez
>>> PC wrote:
>>>> Hi Ed,
>>>> files (like messages_de.properties) are picked up from it (earlier
>>>> English strings i.e. messages.properties.
>>>> Any suggestions?
>>>> Thanks.
>>>> - Parvez
>>>> Ed Merks wrote:
>>>>> Parvez,
>>>>> you looking to do that, or to change the basic English strings?
>>>>> PC wrote:
>>>>>> Hi,
>>>>>> WorkbenchMessages
>>>>>> Thanks.
>>>>>> - Parvez
Previous Topic:NoClassDefFound with contributed ant task
Next Topic:How to disable a view
Current Time: Tue Nov 04 01:34:31 EST 2025
Powered by FUDForum. Page generated in 0.05889 seconds
