Home » Eclipse Projects » Eclipse Platform » why eclipse load the old plugin
why eclipse load the old plugin [message #329041] Wed, 11 June 2008 01:34 Go to next message
Hi, all
I have two plug-ins with different version, they are: x.y.myPlugin(3.0.0)
and x.y.myPlugin(4.0.0).
The problem is that the older one (x.y.myPlugin(3.0.0)) is loaded after
eclipse started.
But I think that eclipse manages all the plug-in and their version as well,
and it should make sure that the newer plug-ins are always loaded.
Did I missing anything?
Thanks & Best Regards!
Nick
Re: why eclipse load the old plugin [message #329047 is a reply to message #329041] Wed, 11 June 2008 04:40 Go to previous messageGo to next message
Nick,
Try running with -clean -debug and looking at the
<workspace>/.metadata/.log. It should describe what plugins are being
activated and the details of that will likely help explain. For example,
the newer plugin might require things that aren't available or there
might be other plugins that specifically require the older version of
the plugin, since plugin dependencies can specify ranges...
Nick Tan wrote:
> Hi, all
> x.y.myPlugin(3.0.0) and x.y.myPlugin(4.0.0).
> after eclipse started.
> well, and it should make sure that the newer plug-ins are always loaded.
> Nick
Re: why eclipse load the old plugin [message #329078 is a reply to message #329047] Thu, 12 June 2008 03:44 Go to previous message
Thanks Ed,
I got it, and it works fine after I set "singleton:=true" for the
Bundle-SymbolicName of the newer plug-in x.y.myPlugin(4.0.0),
But what I wandered is that why eclipse active the old one if I did not set
"singleton:=true" though the two plug-ins are both resolved successfully?
Nick
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:g2o2ur$37r$2@build.eclipse.org...
> Nick,
> Nick Tan wrote:
>> Hi, all
>> Nick
Previous Topic:Prevent plugin installation or warn users about JVM versions
Next Topic:delete action as object contribution ...
Current Time: Fri Nov 14 05:16:27 EST 2025
Powered by FUDForum. Page generated in 0.04068 seconds
