Home » Eclipse Projects » Eclipse Platform » 3.4rc4, manual build failed
3.4rc4, manual build failed [message #329038] Wed, 11 June 2008 00:21 Go to next message
Hi!
I have tried to build (for linux gtk x86_64) last rc4 and have got
plenty of
"The type java.lang.Object cannot be resolved."
and such errors (the same is for prev. rc's). and build ends with:
/wrk/kit/eclipse/34rc4/features/org.eclipse.rcp/build.xml:15 : The following
error occurred while executing this line:
/wrk/kit/eclipse/34rc4/plugins/org.eclipse.equinox.launcher/ build.xml:137:
The following error occurred while executing this line:
/wrk/kit/eclipse/34rc4/plugins/org.eclipse.equinox.launcher/ build.xml:95:
Compile failed; see the compiler error output for details.
build.properties is set in accordance with the doc:
J2SE-1.4="/opt/blackdown-jdk-1.4.2.03"
J2SE-1.5="/opt/sun-jdk-1.5.0.13"
JavaSE-1.6="/opt/sun-jdk-1.6.0.06"
It seems I have missed something obvious. Any thoughts?
Please, help!
Andrew
Re: 3.4rc4, manual build failed [message #329106 is a reply to message #329038] Thu, 12 June 2008 14:27 Go to previous messageGo to next message
Andrew,
The values you give those properties will be used as the bootclasspath
for the javac tasks.
As such, you probably want values more like:
J2SE-1.5=/opt/sun-jdk-1.5.0.13/jre/lib/rt.jar:/opt/sun-jdk-1 .5.0.13/jre/lib/jsse.jar
-Andrew
Andrew Gaydenko wrote:
> Hi!
> plenty of
> Please, help!
> Andrew
Re: 3.4rc4, manual build failed [message #329121 is a reply to message #329106] Fri, 13 June 2008 05:13 Go to previous message
Andrew,
Thanks, it helped!! Just have added jce.jar also (javax.crypto was
missing).
Software updating doesn't work, but this is another (very-very dark
from user's POV) story :-)
Andrew
Andrew Niefer wrote:
> Andrew,
> -Andrew
>> Hi!
>> plenty of
>> Please, help!
>> Andrew
Previous Topic:Cannot contribute custon ant task from fragment plugin
Next Topic:Can decorators modify tooltips
Current Time: Mon Jul 21 20:07:09 EDT 2025
Powered by FUDForum. Page generated in 0.07025 seconds
