Home » Eclipse Projects » Eclipse Platform » Force a plugin to re-start
Force a plugin to re-start [message #329022] Tue, 10 June 2008 12:45 Go to next message
Is it possible to force a plugin to re-start? I'm working on "entitled"
plugins that require a valid license in order to load; if the license is
not valid (or missing entirely), the activator throws an exception from
the start() method.
Now I'd like to give the user the ability to correct his license. After
doing so, I'd like to force the licensed plugins to try to start again
without having to restart the entire workbench. Is that possible?
TIA,
Eric
Re: Force a plugin to re-start [message #329025 is a reply to message #329022] Tue, 10 June 2008 12:57 Go to previous messageGo to next message
Use a bundle context to find your bundle and tell it to start.
Let me know if you need some sample code.
HTH,
Wayne
> the start() method.
> TIA,
> Eric
Re: Force a plugin to re-start [message #329029 is a reply to message #329025] Tue, 10 June 2008 14:56 Go to previous messageGo to next message
Definitely - I'm having trouble finding the bootstraps...
Eric
>> the start() method.
>> TIA,
>> Eric
Re: Force a plugin to re-start [message #329032 is a reply to message #329029] Tue, 10 June 2008 15:14 Go to previous messageGo to next message
Something like this bundle activator ought to do it:
package org.eclipse.funkybundles;
import org.eclipse.core.runtime.Plugin;
import org.osgi.framework.Bundle;
import org.osgi.framework.BundleContext;
import org.osgi.framework.BundleException;
* The activator class controls the plug-in life cycle
public class Activator extends Plugin {
private static Activator plugin;
private BundleContext context;
public void start(BundleContext context) throws Exception {
this.context = context;
super.start(context);
plugin = this;
public void startAllMyFunkyBundles() {
Bundle[] bundles = context.getBundles();
for(int index=0;index<bundles.length;index++) {
Bundle bundle = bundles[index];
if (isThisOneOfMyFunkyBundles(bundle)) {
try {
bundle.start();
} catch (BundleException e) {
// TODO Do something smart with this
e.printStackTrace();
private boolean isThisOneOfMyFunkyBundles(Bundle bundle) {
return bundle.getSymbolicName().matches(".*\\.funky\\..*");
public void stop(BundleContext context) throws Exception {
plugin = null;
super.stop(context);
public static Activator getDefault() {
return plugin;
I'd write a smarter isThisOneOfMyFunkyBundles() method.
This assumes that all your bundles have been installed. I recall (but am
not 100% certain) that start() might throw an exception if the bundle is
already started. I'd probably handle this case in the exception handler
(keep in mind that multiple threads might try to start the bundle
concurrently).
On that note, you might want to either synchronize the method or add a
comment warning against multiple-thread access.
I'm not sure why I decided that your bundles would be "funky". :-)
HTH,
Wayne
> Eric
> >> the start() method.
> >> TIA,
> >> Eric
Re: Force a plugin to re-start [message #329141 is a reply to message #329032] Fri, 13 June 2008 13:05 Go to previous message
I would also use bundle.start(Bundle.START_TRANSIENT); if it available
to you ... that allows the bundle to remain in the lazy state for the
next restart.
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Previous Topic:Retarget Action and Handler
Next Topic:Where is the list of the now-exist PropertyTesters?
Current Time: Mon Sep 01 01:38:20 EDT 2025
Powered by FUDForum. Page generated in 0.04017 seconds
