Home » Eclipse Projects » Eclipse Platform » MarkerView openAction - any way to change its behavior?
MarkerView openAction - any way to change its behavior? [message #329020] Tue, 10 June 2008 11:52
Use-case (& problem):
I have resources, on which there may be markers, but I do not provide an
editor for those resources (instead I have a "model view" through which
the user edits the model, which causes changes in the resources).
So when MarkerView.handleOpenEvent() runs, the selected marker provides
its resource (all fine), but then ActionOpenMarker.run() attempts to call
IDE.openEditor(
part.getSite().getPage(),
marker,
OpenStrategy.activateOnOpen());
(well, in 3.2 and 3.3; I have not checked the code in 3.4).
Desire:
What I'd like is to be able to plug in some action there, that would --
in my case -- activate the Model-View, select the relevant model, and
within that the relevant resource.
thanks,
-Paul
Previous Topic:Doxygen & Eclipse
Next Topic:german umlauts are wrong after exporting RCP application
Current Time: Fri Aug 29 15:00:00 EDT 2025
Powered by FUDForum. Page generated in 0.02198 seconds
