Home » Eclipse Projects » Eclipse Platform » Class can not be found Error
Class can not be found Error [message #328997] Tue, 10 June 2008 04:51 Go to next message
Originally posted by: maxipower_q.yahoo.com
I'm designing a plug-in and i need to get the workspace's path; so i'm
trying some code;
IWorkspace workspace = ResourcesPlugin.getWorkspace();
But first, i could not import library of "IWorkspace" and
"ResourcesPlugin".
i tried adding this library to my eclipse by;
project-> properties -> java build path -> add external jars
so i added; -found them in "C:\Program Files\eclipse\plugins"-
org.eclipse.core.resources.win32_3.3.0.v20070226.jar
org.eclipse.core.resources_3.3.1.R33x_v20080205.jar
org.eclipse.core.resources.compatibility_3.2.100.v20070502.j ar
now i can import their library "org.eclipse.core.resources"
But when i try to run the code, i get the "Class can not be found" runtime
error.
Can someone tell me where is the problem ? and how can i fix it ?
Or is there a way to get the workspace path without using this library?
Re: Class can not be found Error [message #328998 is a reply to message #328997] Tue, 10 June 2008 04:58 Go to previous messageGo to next message
Cumhur,
This is a recurring error that I see again and again. When building
plugins, don't ever mess with the classpath directly via the properties
of the project. Only edit the MANIFEST.MF and change the dependencies
in the Dependencies tab. Otherwise, the compile time problem you fix
will come back again at runtime.
Cumhur Kilic wrote:
> Hi, I'm designing a plug-in and i need to get the workspace's path; so
> i'm trying some code;
> "ResourcesPlugin".
> i tried adding this library to my eclipse by; project-> properties ->
> runtime error.
Re: Class can not be found Error [message #329002 is a reply to message #328998] Tue, 10 June 2008 07:32 Go to previous message
Thanks a lot. It works. You really saved me .
Ed Merks wrote:
> Cumhur,
Previous Topic:Make TableLayoutComposite public
Next Topic:Cathc low level key events (like accent keys), possible in Eclipse?
Current Time: Sat Oct 25 09:08:36 EDT 2025
Powered by FUDForum. Page generated in 0.02583 seconds
