Home » Eclipse Projects » Eclipse Platform » fastview position
fastview position [message #328987] Mon, 09 June 2008 17:47 Go to next message
This is a re-post, as I've had no replies. Any help would be appreciated.
Is it possible to programmatically determine where a fastview will open on
the screen (top, bottom, right side, left side)?
I know I can use
layout.addFastView(String viewID, float ratio)
where ratio determines how much of the screen the fastview will occupy;
however, it doesn't specify where the fastview should appear.
Chad
Re: fastview position [message #329105 is a reply to message #328987] Thu, 12 June 2008 14:23 Go to previous message
Anyone?
> I know I can use
> Chad
Previous Topic:Exclude classes from product export
Next Topic:How to programmatically find path to configuration directory?
Current Time: Thu Nov 06 10:09:43 EST 2025
Powered by FUDForum. Page generated in 0.04234 seconds
