Home » Eclipse Projects » Eclipse Platform » java.lang.StackOverflowError in BundleLoader with version 3.4rc3
java.lang.StackOverflowError in BundleLoader with version 3.4rc3 [message #328887] Thu, 05 June 2008 22:16
I'm hoping someone can provide some feedback / insights into the following
issue i'm seeing.
I've been using the eclipse RCP platform successfully for a rather small
project with about 7 plugins and the required set of plugins for the IDE
application. i've recently switched to 3.4rc3 from the latest 3.3 and i
can't start my app anymore. i'll admit, i've made some changes to my code
in the process, but i believe nothing "too fancy" to cause an issue like
this.
i'm running on sun's JDK 1.6 on windows XP.
all of my manifest files are error / warning free.
i took a look at the source code, and noticed that the method
addExportedProvidersFor keeps track of the "visited" bundles, but it's
re-entering itself in such a way that the local variable "visited" isn't
getting propageted through the other methods.
perhaps i have a circular plugin reference or something, but none of the
tooling is giving me any warnings of that, and i've been running
successfully on 3.3.
again, any insights into a potential problem would be apreciated.
-Richard
org.eclipse.osgi.framework.util.KeyedHashSet.keyHash(KeyedHa shSet.java:380)
org.eclipse.osgi.framework.util.KeyedHashSet.getByKey(KeyedH ashSet.java:209)
org.eclipse.osgi.framework.internal.core.BundleLoaderProxy.g etPackageSource(BundleLoaderProxy.java:159)
org.eclipse.osgi.framework.internal.core.BundleLoaderProxy.c reatePackageSource(BundleLoaderProxy.java:213)
org.eclipse.osgi.framework.internal.core.BundleLoader.create ExportPackageSource(BundleLoader.java:254)
org.eclipse.osgi.framework.internal.core.BundleLoader.getImp ortedSources(BundleLoader.java:239)
org.eclipse.osgi.framework.internal.core.BundleLoader.findIm portedSource(BundleLoader.java:1044)
org.eclipse.osgi.framework.internal.core.BundleLoader.addExp ortedProvidersFor(BundleLoader.java:904)
org.eclipse.osgi.framework.internal.core.BundleLoader.findRe quiredSource(BundleLoader.java:1083)
org.eclipse.osgi.framework.internal.core.BundleLoader.create ExportPackageSource(BundleLoader.java:253)
and the terror continues
Previous Topic:Debugging plugin install problems
Next Topic:want MultiTextEdit to undo at once
Current Time: Wed Nov 05 00:09:24 EST 2025
Powered by FUDForum. Page generated in 0.02959 seconds
