Home » Eclipse Projects » Eclipse Platform » Select All enabled in Variables View when no items are in the view?
Select All enabled in Variables View when no items are in the view? [message #328720] Mon, 02 June 2008 15:03 Go to next message
Open any workspace without any active launches. Open the Variables View
and right-click in the view. The "Select All" menu item appears active
although there are no variables in the view.
Is this a minor issue or is it intended behavior for some reason? I
searched through the Eclipse bugs and didn't see any bug describing this
behavior.
This was noticed with Eclipse v3.3.1.1
Please let me know if there is an existing Ecipse newsgorup that this
question is better suited for.
Re: Select All enabled in Variables View when no items are in the view? [message #328771 is a reply to message #328720] Tue, 03 June 2008 18:31 Go to previous messageGo to next message
Hey Joe,
This newsgroup is fine.
If you have done a search (Google, bugzilla etc.) and the behavior seems
inconsistent to you, as it does for me (though pretty minor), I would log a
bug report and attach a patch to disable the action when the view is empty.
HTH
Darins
http://www.runnerwhocodes.blogspot.com/
"Joe Luebker" <joe_luebker@mentor.com> wrote in message
news:9f1b5d520744da403685479209720533$1@www.eclipse.org...
> behavior.
Re: Select All enabled in Variables View when no items are in the view? [message #328819 is a reply to message #328771] Wed, 04 June 2008 10:04 Go to previous message
Thanks for the response. I was just looking for a bit of feedback before I
entered this as a bug.
Previous Topic:Re: Not able to close single window opened using Window -> New Window in eclipse 3.2
Next Topic:Specifying compilerArg in build.properties for plugins and product build
Current Time: Fri Nov 21 08:15:56 EST 2025
Powered by FUDForum. Page generated in 0.03372 seconds
