Home » Eclipse Projects » Eclipse Platform » Eclipse Shutdown Problem
Eclipse Shutdown Problem [message #328714] |
Mon, 02 June 2008 13:29  |
Occasionally, in haste, I exit windows before exiting Eclipse. When I
subsequently attempt to restart eclipse (on the workspace that was open
when I prematurely exited from windows), the launch process hangs up on
the splash screen, with some of the progress bar showing green. Other
workspaces are unaffected.
My work-around has been (apart from taking more care when exiting
windows), to delete the .metadata/ directory in the affected workspace,
using the file-system browser, then to open the workspace (which
initially has no projects), then to import all the projects. Not
surprisingly, I also loose my java code templates, and other settings,
at this point.
Recently I have found that deleting just the
../metadata/org.eclipse.core.resources directory gets around the
workspace launch problem, but other problems (launching ant project
builders) emerge. It seems that Eclipse is not able to handle my
disorderly conduct (not able to respond appropriately to shutdown
warnings from windows).
Is there a better workaround than deleting .metadata/ ?
Should I report this as a bug?
Bill.
Re: Eclipse Shutdown Problem [message #328715 is a reply to message #328714] |
Mon, 02 June 2008 13:35   |
> at this point.
> Bill.
I should have mentioned, I am running 3.3.1.1 on XP
Re: Eclipse Shutdown Problem [message #328719 is a reply to message #328715] |
Mon, 02 June 2008 14:49   |
>> open when I prematurely exited from windows), the launch process hangs
>> up on the splash screen, with some of the progress bar showing green.
>> Other workspaces are unaffected.
>> workspace, using the file-system browser, then to open the workspace
>> (which initially has no projects), then to import all the projects.
>> Not surprisingly, I also loose my java code templates, and other
>> settings, at this point.
>> Bill.
Apologies, on further investigation, the .metadata/.log file indicates
that this may be a problem with a third party product (OxygenXML), so
I'll take it to them.
Re: Eclipse Shutdown Problem [message #328832 is a reply to message #328714] |
Wed, 04 June 2008 12:59  |
If Eclipse hangs (during startup or otherwise), have a look at:
http://wiki.eclipse.org/How_to_report_a_deadlock
Boris
"Bill Winspur" <bwinspur@wynnon.com> wrote in message
news:g21a3d$igq$1@build.eclipse.org...
> using the file-system browser, then to open the workspace (which initially
> has no projects), then to import all the projects. Not surprisingly, I
> also loose my java code templates, and other settings, at this point.
> ./metadata/org.eclipse.core.resources directory gets around the workspace
> launch problem, but other problems (launching ant project builders)
> emerge. It seems that Eclipse is not able to handle my disorderly conduct
> (not able to respond appropriately to shutdown warnings from windows).
> Bill.
Current Time: Tue Jul 22 00:00:05 EDT 2025
Powered by FUDForum. Page generated in 0.02660 seconds
