Home » Eclipse Projects » Eclipse Platform » UIJob hangs
UIJob hangs [message #328705] Mon, 02 June 2008 10:50 Go to next message
Originally posted by: andrei.serea.ama.us
Hy all
I'm having a problem with an UIJob. I'm trying to schedule and run it when
the user presses a button in a property page, but the platform never runs it
(eclipse hangs on join and the actual job never starts to run).
Any ideas?
Andrei
Re: UIJob hangs [message #328708 is a reply to message #328705] Mon, 02 June 2008 11:25 Go to previous messageGo to next message
Originally posted by: kosta.bea.com
Sounds like you are creating a deadlock situation. Can you post your
thread dumps?
- Konstantin
Re: UIJob hangs [message #328713 is a reply to message #328705] Mon, 02 June 2008 12:53 Go to previous messageGo to next message
If you use join() in the UI thread, you will block the UI thread until
the UIJob finishes --> that will block indefinitely !
Andrei Serea wrote:
> Hy all
> Any ideas?
> Andrei
Re: UIJob hangs [message #652287 is a reply to message #328713] Thu, 03 February 2011 08:33 Go to previous messageGo to next message
Hei!
I don't really understand it - why is the UI thread going to be blocked indefinitely - the UIJob could last only a couple of seconds?!
Best regards
Re: UIJob hangs [message #652304 is a reply to message #652287] Thu, 03 February 2011 09:16 Go to previous messageGo to next message
On 02/03/2011 08:33 AM, Anton wrote:
> Hei!
The UIJob itself posts an asyncExec(*) and then returns
Job.ASYNC_FINISH. But a job.join() will block the calling thread until
something (in this case, the asyncExec) calls Job.done(*). If you
join() on the UI thread, the asyncExec will never get run.
Ta da.
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: UIJob hangs [message #654613 is a reply to message #652304] Wed, 16 February 2011 08:42 Go to previous message
useful for me, thanks
Previous Topic:Comparison Report
Next Topic:LTK: No default action starting Apply Script wizard?
Current Time: Tue Jul 22 15:42:27 EDT 2025
Powered by FUDForum. Page generated in 0.11003 seconds
