Home » Eclipse Projects » Eclipse Platform » [DataBinding] Using ControlDecoration in data binding snippets
[DataBinding] Using ControlDecoration in data binding snippets [message #328671] Sat, 31 May 2008 07:04 Go to next message
Originally posted by: malloovidio.bluewin.ch
Hi all,
I wanted to use the ControlDecoration class to visualize the validation
status of a Binding on the corresponding UI control. In order to retrieve
the decoration images predefined in JFace, I'm using the following code
FieldDecorationRegistry.getDefault().getFieldDecoration(
FieldDecorationRegistry.DEC_ERROR).getImage();
However, this always results in the below exception being thrown as the
images seem not to be found. I guess it's once more some CLASSPATH/ClassLoader
problem but I cannot figure out what I have to do to be able to use those
images from within the data binding snippets (without having to hardcode
the images' path).
Any suggenstions? Thanks in advance!
Ovidio
The image could not be loaded: FileImageDescriptor(location=class
org.eclipse.jface.fieldassist.FieldDecorationRegistry, name=images/error_ovr.gif)
org.eclipse.jface.resource.DeviceResourceException: Unable to create resource
org.eclipse.jface.resource.ImageDescriptor.createResource(Im ageDescriptor.java:167)
org.eclipse.jface.resource.DeviceResourceManager.allocate(De viceResourceManager.java:56)
org.eclipse.jface.resource.AbstractResourceManager.create(Ab stractResourceManager.java:88)
org.eclipse.jface.resource.ResourceManager.createImageWithDe fault(ResourceManager.java:192)
at org.eclipse.jface.resource.ImageRegistry.get(ImageRegistry.j ava:211)
org.eclipse.jface.fieldassist.FieldDecorationRegistry$Entry. getDecoration(FieldDecorationRegistry.java:197)
org.eclipse.jface.fieldassist.FieldDecorationRegistry.recomp uteMaximums(FieldDecorationRegistry.java:401)
org.eclipse.jface.fieldassist.FieldDecorationRegistry.regist erFieldDecoration(FieldDecorationRegistry.java:348)
org.eclipse.jface.fieldassist.FieldDecorationRegistry.<clinit >(FieldDecorationRegistry.java:138)
org.eclipse.jface.examples.databinding.snippets.Snippet000He lloWorld$1.run(Snippet000HelloWorld.java:41)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
org.eclipse.jface.examples.databinding.snippets.Snippet000He lloWorld.main(Snippet000HelloWorld.java:38)
Re: [DataBinding] Using ControlDecoration in data binding snippets [message #328686 is a reply to message #328671] Mon, 02 June 2008 04:50 Go to previous messageGo to next message
Hi again,
it seems as if it was some bug. I was having that problem with Eclipse
Ganymed M6 but with the RC1 version which I have just downloaded, the
exception is gone.
Ovidio
Ovidio Mallo wrote:
> Hi all,
> the images' path).
> Ovidio
> resource FileImageDescriptor(location=class
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: [DataBinding] Using ControlDecoration in data binding snippets [message #328687 is a reply to message #328686] Mon, 02 June 2008 05:15 Go to previous message
Yes there was a change in how ImageDescriptors work and there was a bug
introduced some time in the dev-cycle.
Tom
Ovidio Mallo schrieb:
> Hi again,
> exception is gone.
> Ovidio
> Ovidio Mallo wrote:
>> Hi all,
>> the images' path).
>> Regards,
>> Ovidio
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Previous Topic:Not able to right click the project tree view on hte left pane in eclipse 3.3.2
Next Topic:Combining wizards
Current Time: Mon Nov 10 04:27:43 EST 2025
Powered by FUDForum. Page generated in 0.04107 seconds
