Home » Eclipse Projects » Eclipse Platform » How to fit the wizard for different resolution montiors
How to fit the wizard for different resolution montiors [message #328669] Fri, 30 May 2008 16:31 Go to next message
Originally posted by: x_devan.ugs.com
Hi All,
I have created a wizard with 6 text field in it. It is working fine as
expected.
I have a desktop with 21 inch monitor and with the resolution of 2048 X
1024.
When I launch my application and invoke the wizard in a laptop (15 inch
screen with the resolution of 1680 X 1024), one of the text field is getting
hidden, i need to resize the wizard manually to see the field.
Is there a way i can automatically set the wizard size ?
Hemanth
Re: How to fit the wizard for different resolution montiors [message #328670 is a reply to message #328669] Sat, 31 May 2008 02:39 Go to previous messageGo to next message
Hemanth,
Probably you are not properly using the layout. Is it possible to share
us the wizard page code?
- Prakash
Eclipse Tips: http://blog.cypal-solutions.com
Eclipse Search: http://www.cypal.in/eclipsesearch
Hemanth wrote:
> Hi All,
> expected.
> 1024.
getting
> Hemanth
Re: How to fit the wizard for different resolution montiors [message #328700 is a reply to message #328670] Mon, 02 June 2008 09:34 Go to previous messageGo to next message
here is the extract from the wizard page code,
public void createControl( Composite parent )
Composite composite = new Composite( parent, SWT.NONE );
// set the layout
GridLayout layout = new GridLayout();
layout.numColumns = 3;
composite.setLayout( layout );
//Adding the fields.
setControl( composite );
Hemanth
"Prakash G.R." <grprakash@gmail.com> wrote in message
news:4840F29B.4090905@gmail.com...
> Hemanth,
> Probably you are not properly using the layout. Is it possible to share us
> - Prakash
> Hemanth wrote:
> > Hi All,
> > expected.
> > 1024.
> getting
> > Regards,
> > Hemanth
Re: How to fit the wizard for different resolution montiors [message #328712 is a reply to message #328700] Mon, 02 June 2008 12:41 Go to previous message
Are you setting any layout data to the text controls? Something like:
new GridData(SWT.FILL, SWT.NONE, true, false)?
- Prakash
www.eclipse-tips.com
> // set the layout
> Hemanth
>> Hemanth,
>> - Prakash
>> Hemanth wrote:
>>> Hi All,
>>> expected.
>>> 1024.
>> getting
>>> Regards,
>>> Hemanth
Previous Topic:Re: RC3 wont start on Ubuntu: XPCOM Mozilla error
Next Topic:importing the javaeditor example
Current Time: Sat Jul 26 14:11:47 EDT 2025
Powered by FUDForum. Page generated in 0.04737 seconds
