Home » Eclipse Projects » Eclipse Platform » DnD - FileTransfer - Resource not Found
DnD - FileTransfer - Resource not Found [message #328647] Thu, 29 May 2008 16:43
Originally posted by: marcio.debarros.gmail.com
I am trying to implement Drag and Drop between two views, the source
view only allows Drag and is an extension the CNF.
The target view only allows drop and is TreeViewer view.
I am able to drag the object (a file) from the source view and drop on
the appropriate receiver object in the target view. Note that I don't
want to loose the original file, just create a copy of it to send to the
drop target.
While debugging I go as far as seeing the full path of the dragged file,
but once I try to read its contents I get a ResourceException, saying
that the file does not exist.
If I look on the source view, and on the file system, the file is still
there.
Here is how I set the drop support on my view:
int operations = DND.DROP_COPY;
Transfer[] types = new Transfer[] {FileTransfer.getInstance()};
dropAdapter = new MessageTreeDropAdapter(brokerViewer);
brokerViewer.addDropSupport(operations, types, dropAdapter);
I tried before operations = DND.DROP_COPY | DND.DROP_MOVE and still the
same result.
Any suggestions or ideas on what I may be doing wrong ?
--MD.
Previous Topic:Re: Problems with Wizard pages
Next Topic:fastview position
Current Time: Tue Jul 22 21:24:57 EDT 2025
Powered by FUDForum. Page generated in 0.36813 seconds
