Home » Eclipse Projects » Eclipse Platform » Need help to get ContextMenu for Shell Trim
Need help to get ContextMenu for Shell Trim [message #328612] Wed, 28 May 2008 11:44 Go to next message
I have a SashForm in my application, the left site of the SashForm is a
Composite, and it contains several TableViewer for easy navigation, I
just call it ShellTrim; On the right site of the SashForm, I have a
perspective with one or more views. I used eclipse 3.3 context menu
declare mechanism to declare a context menu for my views. The context
menu works well for the views.
I want the same context menu show up when I right mouse click on an item
from a TableViewer of ShellTrim. Since my ShellTrim is not a view, I
cannot register any context menu for it; and for some reason, I cannot
make it a view. Now, I have no idea how to hook the context menu with
my ShellTrim's TableViewer. I really appreciate any help and hint.
Thanks a lot !
Hongying Zhang
Re: Need help to get ContextMenu for Shell Trim [message #328923 is a reply to message #328612] Fri, 06 June 2008 14:09 Go to previous message
You might be able to create your own MenuManager and use the
IMenuService to populate it. If your view has any programmatic
contributions, you'll have to figure out a way to share those manually.
The one thing that won't work (at least not well) is standard object
contributions. Although if your view and ShellTrim were always open,
you can figure out a way for the view to provide ShellTrim with its own
separate context menu
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Previous Topic:org.eclipse.ui.commands defaultHandler isA?
Next Topic:Jface Accelerator Not working untill menu is popped once
Current Time: Sun Oct 26 05:19:52 EDT 2025
Powered by FUDForum. Page generated in 0.05469 seconds
