Home » Eclipse Projects » Eclipse Platform » Vista Bug using Nebula CDatetime
Vista Bug using Nebula CDatetime [message #328563] Tue, 27 May 2008 12:45 Go to next message
Hi all,
I encounter a strange behaviour with Vista :
I use Nebula.CDatetime as datafield and as tableViewerColumn editor and
it works fine, except that when I pick a date (Fron Calendar), main menu
bar and icons toolbar disappears !
I didn't investigate at all because I encounter this behaviour only on
Windows Vista : it's OK on Windows2000 and Windows XP !!!
Any idea ?
Thanks in advance,
Richard Desbiolles
Re: Vista Bug using Nebula CDatetime [message #328566 is a reply to message #328563] Tue, 27 May 2008 13:06 Go to previous messageGo to next message
Do you by chance have a Snippet we can run? What version of SWT are you
using?
Tom
Richard Desbiolles schrieb:
> Hi all,
> Any idea ?
> Thanks in advance,
> Richard Desbiolles
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: Vista Bug using Nebula CDatetime [message #328568 is a reply to message #328566] Tue, 27 May 2008 13:21 Go to previous messageGo to next message
> using?
> Tom
>> Hi all,
>> and it works fine, except that when I pick a date (Fron Calendar),
>> main menu bar and icons toolbar disappears !
>> Any idea ?
>> Thanks in advance,
>> Regards,
>> Richard Desbiolles
I have just installed 3.4 M7 (it makes me happy because it solves a
CheckBox column editor problem, using your BooleanColumnCellEditor).
Richard
Re: Vista Bug using Nebula CDatetime [message #328569 is a reply to message #328566] Tue, 27 May 2008 13:25 Go to previous messageGo to next message
> using?
> Tom
>> Hi all,
>> Any idea ?
>> Thanks in advance,
>> Regards,
>> Richard Desbiolles
Sorry, I answered a little quickly !
About the snippet, itsn't really easy for me because I have a lot of
software around the basic functionnalities, but if the bug isn't known,
I can try to create such a snippet.
Richard
Re: Vista Bug using Nebula CDatetime [message #328602 is a reply to message #328566] Tue, 27 May 2008 23:11 Go to previous messageGo to next message
--------------000707050603060109060802
Tom Schindl a
Re: Vista Bug using Nebula CDatetime [message #328788 is a reply to message #328566] Tue, 03 June 2008 22:01 Go to previous messageGo to next message
--------------030900090108010808030108
Tom Schindl a
Vista Bug using Nebula CDatetime [message #328952 is a reply to message #328566] Sun, 08 June 2008 00:57 Go to previous messageGo to next message
--------------050200030906090509080702
Tom Schindl a
Vista Bug using Nebula CDatetime [message #329452 is a reply to message #328566] Tue, 24 June 2008 22:32 Go to previous messageGo to next message
--------------080208080605030300010208
Tom Schindl a
Re: Vista Bug using Nebula CDatetime [message #329455 is a reply to message #329452] Wed, 25 June 2008 02:30 Go to previous message
Please see the answer from Jermey on the nebula group there's a thread
with "No more handles".
Tom
>> you using?
>> Tom
>>> Hi all,
>>> on Windows Vista : it's OK on Windows2000 and Windows XP !!!
>>> Any idea ?
>>> Thanks in advance,
>>> Regards,
>>> Richard Desbiolles
> A snippet is joined.
> Best regards,
> richard desbiolles
Previous Topic:Help search behavior
Next Topic:Unhandled event loop exception
Current Time: Mon Nov 10 18:16:41 EST 2025
Powered by FUDForum. Page generated in 0.06438 seconds
