Home » Eclipse Projects » Eclipse Platform » Adding Listener to Process Editor in Business Modeler
Adding Listener to Process Editor in Business Modeler [message #328506] Mon, 26 May 2008 15:59 Go to next message
Originally posted by: lbarbour.gmail.com
I am trying to build a plug-in for WebSphere Business Modeler Advanced v.
6.0.2. It tracks changes in the process models, and lists them in a view.
I am trying to add a listener to the process editor. I need to record when
changes occur (such as addition of an element, a name change, etc), what
the change is, and which elements are affected.
I am having trouble determining which listener to use, and where to add
it. Do I apply it to the process editor? I have been able to add a
selection listener, but I want my plug-in to automatically update when a
change occurs.
Re: Adding Listener to Process Editor in Business Modeler [message #328538 is a reply to message #328506] Tue, 27 May 2008 09:13 Go to previous message
Lili,
I think you should be asking this question on a forum where that product
is directly supported. If the modeler is using EMF then likely the
objects in the editor are EObjects and hence Notifiers, so it would be
possible to attach an EContentAdapter to the root ResourceSet of the
editor (if it even provides API-based access to that) to listen to all
changes that occur to any object in that editor.
> v. 6.0.2. It tracks changes in the process models, and lists them in a
> view.
> when changes occur (such as addition of an element, a name change,
> etc), what the change is, and which elements are affected.
> add it. Do I apply it to the process editor? I have been able to add a
> a change occurs.
Previous Topic:fast view position
Next Topic:Plugins dowloader and manager
Current Time: Fri Nov 07 21:32:12 EST 2025
Powered by FUDForum. Page generated in 0.24383 seconds
