Home » Eclipse Projects » Eclipse Platform » TreeViewer with a ViewerFilter and empty nodes with expand buttons
TreeViewer with a ViewerFilter and empty nodes with expand buttons [message #328493] Mon, 26 May 2008 11:49 Go to next message
Originally posted by: nn.nnn.com
I have a TreeViewer with a ViewerFilter. When a parent node has some
children but they are all filtered out, it still gets the plus
expand/collapse button. Is this normal behavior or can I fix this somehow?
Re: TreeViewer with a ViewerFilter and empty nodes with expand buttons [message #328494 is a reply to message #328493] Mon, 26 May 2008 12:08 Go to previous messageGo to next message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=203950
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: TreeViewer with a ViewerFilter and empty nodes with expand buttons [message #328541 is a reply to message #328493] Tue, 27 May 2008 09:43 Go to previous message
As it stands right now, you have to embed knowledge of the viewer
filters into the content provider - not ideal, but it does work. It
helps to make the implementation of the filters an abstraction above
both JFace interfaces (ViewerFilter and ITreeContentProvider) to make
the sharing a little easier.
Actually, now that I think about it, I suppose that if the content
provider knows about the filters, you don't need ViewerFilter at all...
Hope this helps,
Eric
Previous Topic:Plugins dowloader and manager
Next Topic:How to extend Eclipse Delete
Current Time: Fri Sep 12 21:22:30 EDT 2025
Powered by FUDForum. Page generated in 0.03969 seconds
