Home » Eclipse Projects » Eclipse Platform » Platform configuration has been modified outside this program???
Platform configuration has been modified outside this program??? [message #328479] Mon, 26 May 2008 08:34 Go to next message
I just bumped into this one:
I tried to do a Help => Software Update => Find and Install and got:
Requested operation cannot be performed because it would invalidate the
current configuration. See details for more information.
Platform configuration has been modified outside this program. A
restart is recommended.
Though I have no idea, who or what could cause this (I haven't touched
my eclipse configuration in at least 2 months...) I restarted eclipse as
recommendd and then tried again, but same result.
How can I kick eclipse to refresh or adopt the current configuration so
I can have a check what's new?
Michael
Re: Platform configuration has been modified outside this program??? [message #328483 is a reply to message #328479] Mon, 26 May 2008 09:05 Go to previous messageGo to next message
> Michael
Hello Michael,
you might try to start Eclipse with the -clean parameter, maybe that helps.
Dirk
Re: Platform configuration has been modified outside this program??? [message #328526 is a reply to message #328483] Tue, 27 May 2008 05:07 Go to previous message
> Dirk
I *ALWAYS* start eclipse with -clean (it's part of my eclipse shortcut,
since that caching caused me more trouble than good...).
So, that didn't help. Other ideas or suggestions?
Michael
Previous Topic:Very fast Job leaves behind two entries in progress viewer
Next Topic:Problems with launch configuration tab
Current Time: Sun Aug 31 13:05:14 EDT 2025
Powered by FUDForum. Page generated in 0.03060 seconds
