Home » Eclipse Projects » Eclipse Platform » problem with eclipse ctrl - c (system clipboard stops to work)
problem with eclipse ctrl - c (system clipboard stops to work) [message #328468] Mon, 26 May 2008 04:52 Go to next message
hi all,
not sure this is the right place where I can ask this question ...
since I started using eclipse 3.3.x I'm having trouble with ctrl-c ctrl-v
(copy and paste)...
I have noticed that the problem sometimes happens when I have got microsoft
outlook open (witch use as internal editor winword) ...
after I while ... don't ask me why ... my system clipboard stops to work ...
and I need to log off/on to be able again to perform a copy operation.
is he just me having this problem?
Kar
Re: problem with eclipse ctrl - c (system clipboard stops to work) [message #328753 is a reply to message #328468] Tue, 03 June 2008 12:38 Go to previous message
"KarSc" <carmeloscala@hotmail.com> wrote in message
news:g1dtoc$vjo$1@build.eclipse.org...
> hi all,
> (copy and paste)...
> microsoft outlook open (witch use as internal editor winword) ...
> ... and I need to log off/on to be able again to perform a copy operation.
Something like this has been reported previously, but no one has found a way
to reproduce it reliably enough to fix it, if I recall. You might try
searching Bugzilla.
Previous Topic:how can i tile editors programmatically
Next Topic:Filtering (debug) console output
Current Time: Sun Nov 09 05:01:22 EST 2025
Powered by FUDForum. Page generated in 0.03308 seconds
