Home » Eclipse Projects » Eclipse Platform » How to update an RCP app
How to update an RCP app [message #328340] Thu, 22 May 2008 05:04 Go to next message
Originally posted by: fbanica.soluta.net
Hi all,
I have this problem. I was asked to create an updater for an RCP
application. Basically, when selecting some menu item the application should
connect to a site and get a newer version. It shouldn't be so complicated as
the Update Manager, but only presenting a list with different version of the
application and, when selected, download the archive...
Any idea of how can I do this? Please, help!
Floppy
Re: How to update an RCP app [message #328360 is a reply to message #328340] Fri, 23 May 2008 04:36 Go to previous messageGo to next message
Nobody? Really?
"Florin Banica" <fbanica@soluta.net> wrote in message
news:g13cu6$e0j$1@build.eclipse.org...
> Hi all,
> should
> as
> the
> Floppy
Re: How to update an RCP app [message #328366 is a reply to message #328340] Fri, 23 May 2008 07:31 Go to previous message
as you said you can use the update manager in your RCP application to
automatically update the application. you have to create features and
updates sites fo the update manager to work.
Then you can restrict the update manager to only show your RCP features
http://www.richclient2.eu/2007_07_03/updates-for-rcp-dummies -restricting-the-update-manager/
Florin Banica wrote:
> Hi all,
> Floppy
Previous Topic:Why is it needed for java bean to implement property change support
Next Topic:Problems building a plugin after changing to Eclipse SDK download
Current Time: Fri Aug 15 15:18:25 EDT 2025
Powered by FUDForum. Page generated in 0.03979 seconds
