Home » Eclipse Projects » Eclipse Platform » TableViewerColume and editing
TableViewerColume and editing [message #328265] Tue, 20 May 2008 10:33 Go to next message
Hi all
I'm using TableViewerColum to set label provider and editing support for my
table viewer. (see snippet 19 about new api)
What I find annoying is that each time the cursor goes on the editable cell
immediately the cell goes in editing . is there any way to stop this
behaviors and use F2 (via keylistener to fire the editing) or a rename
action from the context menu?
Kar
Re: TableViewerColume and editing [message #328267 is a reply to message #328265] Tue, 20 May 2008 10:40 Go to previous messageGo to next message
Sure. You'll have to tweak your ColumnViewerEditorActivationStrategy and
only allow editor activation on PROGRAMMATIC and TABBING Events.
Afterwards you activate an editor using TableViewer#editElement() to
fire up the editor on keypress.
Tom
KarSc schrieb:
> Hi all
> my table viewer. (see snippet 19 about new api)
> cell immediately the cell goes in editing . is there any way to stop
> this behaviors and use F2 (via keylistener to fire the editing) or a
> rename action from the context menu?
> Thanks
> Kar
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: TableViewerColume and editing [message #328271 is a reply to message #328267] Tue, 20 May 2008 11:26 Go to previous messageGo to next message
Hi Tom thanks for ur help but still not able to let table works as I want
I'm sure I'm using the ColumnViewerEditorActionStrategy class in a wrong way
here is my code ... what have I done wrong (the class is not called) ???
thanks
Kar
private void initLabelProvider(TableViewer viewer)
TableViewerColumn column = new TableViewerColumn(viewer, SWT.NONE);
column.setLabelProvider(new NameLabelProvider(viewer));
column.setEditingSupport(new NameEditing(viewer));
column.getColumn().setWidth(200);
column.getColumn().setText("Name");
column.getColumn().setMoveable(true);
column.setLabelProvider(new SizeLabelProvider());
column.getColumn().setWidth(150);
column.getColumn().setText("Size");
column.setLabelProvider(new TypeLabelProvider());
column.getColumn().setWidth(100);
column.getColumn().setText("Type");
column.setLabelProvider(new LockedByLabelProvider());
column.getColumn().setText("Locked by");
column.setLabelProvider(new StatusLabelProvider());
column.getColumn().setText("Status");
new ColumnViewerEditorActivationStrategy(viewer)
protected boolean
isEditorActivationEvent(ColumnViewerEditorActivationEvent event)
return event.keyCode == SWT.F2;
"Tom Schindl" <tom.schindl@bestsolution.at> ha scritto nel messaggio
news:g0unt8$hd3$1@build.eclipse.org...
> Afterwards you activate an editor using TableViewer#editElement() to fire
> Tom
> KarSc schrieb:
>> Hi all
>> cell immediately the cell goes in editing . is there any way to stop this
>> Thanks
>> Kar
Re: TableViewerColume and editing [message #328273 is a reply to message #328271] Tue, 20 May 2008 11:33 Go to previous messageGo to next message
Take a look at this snippet
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.jface.s nippets/Eclipse%20JFace%20Snippets/org/eclipse/jface/snippet s/viewers/Snippet044NoColumnTableViewerKeyboardEditing.java? view=markup
Tom
> want ...
> way ...
> thanks
> Kar
> @Override
> protected boolean
>> and only allow editor activation on PROGRAMMATIC and TABBING Events.
>> Tom
>> KarSc schrieb:
>>> Hi all
>>> for my table viewer. (see snippet 19 about new api)
>>> editable cell immediately the cell goes in editing . is there any way
>>> to stop this behaviors and use F2 (via keylistener to fire the
>>> editing) or a rename action from the context menu?
>>> Thanks
>>> Kar
Re: TableViewerColume and editing [message #328274 is a reply to message #328273] Tue, 20 May 2008 11:50 Go to previous messageGo to next message
I did found the example but I was using the TableViewerEditor.create without
the focus cell manager ...
guess without doesn't work ...
but where do I get the FocusBorderCellHighlighter is it part of 3.4Mx?
thanks
news:g0uqvq$dvn$1@build.eclipse.org...
> Tom
>> way ...
>> thanks
>> Kar
>> SWT.NONE);
>> @Override
>> protected boolean
>>> Tom
>>> KarSc schrieb:
>>>> Hi all
>>>> Thanks
>>>> Kar
Re: TableViewerColume and editing [message #328275 is a reply to message #328274] Tue, 20 May 2008 11:59 Go to previous messageGo to next message
No you don't need the highlighter. It should work without it.
Tom
> without the focus cell manager ...
> thanks
>> Tom
>>> want ...
>>> wrong way ...
>>> thanks
>>> Kar
>>> SWT.NONE);
>>> @Override
>>> protected boolean
>>>> Tom
>>>> KarSc schrieb:
>>>>> Hi all
>>>>> support for my table viewer. (see snippet 19 about new api)
>>>>> way to stop this behaviors and use F2 (via keylistener to fire the
>>>>> Thanks
>>>>> Kar
Re: TableViewerColume and editing [message #328301 is a reply to message #328275] Wed, 21 May 2008 03:46 Go to previous messageGo to next message
Hi Tom ... it doesn't work ... can u help me ... please.
Ciao
Kar
protected TableViewer createViewer(Composite parent)
TableViewer viewer = new TableViewer(parent, SWT.H_SCROLL |
SWT.V_SCROLL | SWT.BORDER
| SWT.VIRTUAL | SWT.FULL_SELECTION);
viewer.setUseHashlookup(true);
Table table = viewer.getTable();
// Turn on the header and the lines
table.setHeaderVisible(true);
table.setLinesVisible(true);
initContentProvider(viewer);
initLabelProvider(viewer);
return viewer;
ColumnViewerEditorActivationStrategy actSupport = new
viewer)
protected boolean
return event.eventType ==
ColumnViewerEditorActivationEvent.TRAVERSAL
|| event.eventType ==
ColumnViewerEditorActivationEvent.MOUSE_DOUBLE_CLICK_SELECTI ON
|| (event.eventType ==
ColumnViewerEditorActivationEvent.KEY_PRESSED && event.keyCode == SWT.CR)
|| event.eventType ==
ColumnViewerEditorActivationEvent.PROGRAMMATIC;
TableViewerEditor.create(viewer, actSupport,
ColumnViewerEditor.TABBING_HORIZONTAL
| ColumnViewerEditor.TABBING_MOVE_TO_ROW_NEIGHBOR
| ColumnViewerEditor.TABBING_VERTICAL
| ColumnViewerEditor.KEYBOARD_ACTIVATION);
TableViewerEditor.create(viewer, new
protected boolean
System.out.println("here ..." + event.keyCode);
}, ColumnViewerEditor.TABBING_HORIZONTAL
| ColumnViewerEditor.TABBING_VERTICAL |
news:g0ushv$fk$1@build.eclipse.org...
> Tom
>> thanks
>>> Tom
>>>> want ...
>>>> wrong way ...
>>>> thanks
>>>> Kar
>>>> SWT.NONE);
>>>> @Override
>>>> protected boolean
>>>>> Tom
>>>>> KarSc schrieb:
>>>>>> Hi all
>>>>>> Thanks
>>>>>> Kar
Re: TableViewerColume and editing [message #328303 is a reply to message #328275] Wed, 21 May 2008 04:20 Go to previous messageGo to next message
Messaggio multiparte in formato MIME.
------=_NextPart_000_002C_01C8BB2C.58BBD8C0
Content-Type: text/plain;
charset="iso-8859-1"
sorry I forgot to remove the comment bit ...
TableViewerColumn column =3D new TableViewerColumn(viewer, =
SWT.NONE);
column =3D new TableViewerColumn(viewer, SWT.NONE);
ColumnViewerEditorActivationStrategy actSupport =3D new =
viewer)
protected boolean =
return event.eventType =3D=3D =
|| (event.eventType =3D=3D =
ColumnViewerEditorActivationEvent.KEY_PRESSED && event.keyCode =3D=3D =
SWT.F2)
=20
Content-Type: text/html;
<HTML><HEAD>
charset=3Dunicode">
<META content=3D"MSHTML 6.00.6000.16587" name=3DGENERATOR></HEAD>
<BODY id=3DMailContainerBody=20
style=3D"PADDING-RIGHT: 10px; PADDING-LEFT: 10px; PADDING-TOP: 15px"=20
bgColor=3D#ffffff leftMargin=3D0 topMargin=3D0 CanvasTabStop=3D"true"=20
name=3D"Compose message area"><FONT face=3DCalibri size=3D2>sorry I =
forgot to remove=20
the comment bit ...<BR><BR><BR>&nbsp;private void =
initLabelProvider(TableViewer=20
viewer)<BR>&nbsp;&nbsp;&nbsp; =
{<BR> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;=20
TableViewerColumn column =3D new TableViewerColumn(viewer,=20
SWT.NONE);<BR> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;=20
column.setLabelProvider(new=20
NameLabelProvider(viewer));<BR> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;=
=20
column.setEditingSupport(new=20
NameEditing(viewer));<BR> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;=20
column.getColumn().setWidth(200);<BR> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; =
&nbsp;=20
column.getColumn().setText("Name");<BR>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbs=
p;&nbsp;=20
column.getColumn().setMoveable(true);<BR><BR>&nbsp;&nbsp;&nbsp;&nbsp;&nbs=
p;&nbsp;&nbsp;=20
SizeLabelProvider());<BR> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;=20
column.getColumn().setWidth(150);<BR> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; =
&nbsp;=20
column.getColumn().setText("Size");<BR>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbs=
p;&nbsp;=20
p;&nbsp;&nbsp;=20
TypeLabelProvider());<BR> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;=20
column.getColumn().setWidth(100);<BR> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; =
&nbsp;=20
column.getColumn().setText("Type");<BR>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbs=
p;&nbsp;=20
p;&nbsp;&nbsp;=20
LockedByLabelProvider());<BR> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;=20
&nbsp;=20
column.getColumn().setText("Locked=20
by");<BR> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;=20
p;&nbsp;&nbsp;=20
StatusLabelProvider());<BR> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;=20
&nbsp;=20
column.getColumn().setText("Status");<BR>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&n=
bsp;&nbsp;=20
p;&nbsp;&nbsp;=20
ColumnViewerEditorActivationStrategy actSupport =3D new=20
ColumnViewerEditorActivationStrategy(<BR>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&n=
bsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&n bsp;&nbsp;&nbsp;&nbsp;=20
viewer)<BR> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;=20
{<BR> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;=20
protected boolean =
isEditorActivationEvent(ColumnViewerEditorActivationEvent=20
event)<BR> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nb=
sp;=20
{<BR> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&n=
return event.eventType =3D=3D=20
ColumnViewerEditorActivationEvent.TRAVERSAL<BR>&nbsp;&nbsp;&nbsp;&nbsp;&n=
bsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&n bsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&n b=
sp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nb sp;=20
ColumnViewerEditorActivationEvent.MOUSE_DOUBLE_CLICK_SELECTI ON <BR>&nbsp;&=
nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;& nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;& n=
|| (event.eventType =3D=3D ColumnViewerEditorActivationEvent.KEY_PRESSED =
&amp;&amp;=20
event.keyCode =3D=3D=20
SWT.F2)<BR> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&n=
sp;=20
ColumnViewerEditorActivationEvent.PROGRAMMATIC;<BR>&nbsp;&nbsp;&nbsp;&nbs=
p;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbs p;&nbsp;=20
}<BR> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;=20
};<BR><BR> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;=20
TableViewerEditor.create(viewer,=20
actSupport,<BR> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbs=
p;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;=20
ColumnViewerEditor.TABBING_HORIZONTAL<BR>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&n=
sp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;=20
|=20
ColumnViewerEditor.TABBING_MOVE_TO_ROW_NEIGHBOR<BR>&nbsp;&nbsp;&nbsp;&nbs=
p;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbs p;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbs p=
;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp ;&nbsp;=20
|=20
ColumnViewerEditor.TABBING_VERTICAL<BR>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbs=
|=20
ColumnViewerEditor.KEYBOARD_ACTIVATION);<BR><BR>&nbsp;&nbsp;&nbsp;&nbsp;&=
<BR>&nbsp;&nbsp;&nbsp; }</FONT></BODY></HTML>
------=_NextPart_000_002C_01C8BB2C.58BBD8C0--
Re: TableViewerColume and editing [message #328304 is a reply to message #328301] Wed, 21 May 2008 04:22 Go to previous messageGo to next message
Ah I see you have multiple columns. I thought you have only one column
and do the activation always using TableViewer#editElement(). In this
case you need a the SWTCellFocusManager like it is shown in [1]. Of
course you'll need to replace TreeViewerCellFocusManager through
TableViewerCellFocusManager the rest is the same.
Because your columns are moveable you'll have to use JFace 3.4 because
we had bugs in the case in 3.3.
Tom
[1] http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.jface.s nippets/Eclipse%20JFace%20Snippets/org/eclipse/jface/snippet s/viewers/Snippet026TreeViewerTabEditing.java?view=markup
> Ciao
> Kar
> return viewer;
> viewer)
> protected boolean
> || event.eventType ==
> || (event.eventType ==
> || event.eventType ==
> @Override
> protected boolean
>> Tom
>>> thanks
>>>> Tom
>>>>> I want ...
>>>>> wrong way ...
>>>>> called) ???
>>>>> thanks
>>>>> Kar
>>>>> SWT.NONE);
>>>>> @Override
>>>>> protected boolean
>>>>> messaggio news:g0unt8$hd3$1@build.eclipse.org...
>>>>>> ColumnViewerEditorActivationStrategy and only allow editor
>>>>>> activation on PROGRAMMATIC and TABBING Events. Afterwards you
>>>>>> activate an editor using TableViewer#editElement() to fire up the
>>>>>> editor on keypress.
>>>>>> Tom
>>>>>> KarSc schrieb:
>>>>>>> Hi all
>>>>>>> the editing) or a rename action from the context menu?
>>>>>>> Thanks
>>>>>>> Kar
Re: TableViewerColume and editing [message #328309 is a reply to message #328304] Wed, 21 May 2008 07:26 Go to previous messageGo to next message
I see ... thanks for ur help ... but right now I cannot move to use 3.4 so
guess I will use the old celleditor
:-) many thanks tom
Ciao
news:g10m3o$17s$1@build.eclipse.org...
> Ah I see you have multiple columns. I thought you have only one column and
> do the activation always using TableViewer#editElement(). In this case you
> need a the SWTCellFocusManager like it is shown in [1]. Of course you'll
> Because your columns are moveable you'll have to use JFace 3.4 because we
> Tom
>> Ciao
>> Kar
>> return viewer;
>> SWT.NONE);
>> viewer)
>> protected boolean
>> || event.eventType ==
>> || (event.eventType ==
>> || event.eventType ==
>> @Override
>> protected boolean
>>> Tom
>>>> thanks
>>>>> Tom
>>>>>> want ...
>>>>>> wrong way ...
>>>>>> thanks
>>>>>> Kar
>>>>>> SWT.NONE);
>>>>>> @Override
>>>>>> protected boolean
>>>>>>> Tom
>>>>>>> KarSc schrieb:
>>>>>>>> Hi all
>>>>>>>> Thanks
>>>>>>>> Kar
Re: TableViewerColume and editing [message #328311 is a reply to message #328309] Wed, 21 May 2008 07:46 Go to previous message
Well at least you can avoid the single click activation because this
doesn't need a focus manager, only keyboard activation needs to know
which cell holds the focus to activate the appropriate one. Activation
on double click doesn't need it because it knows which cell the user
clicked.
Tom
> so guess I will use the old celleditor
> :-) many thanks tom
> Ciao
>> Tom
>>> Ciao
>>> Kar
>>> return viewer;
>>> SWT.NONE);
>>> viewer)
>>> protected boolean
>>> || event.eventType ==
>>> || (event.eventType ==
>>> SWT.CR)
>>> || event.eventType ==
>>> @Override
>>> protected boolean
>>>> Tom
>>>>> TableViewerEditor.create without the focus cell manager ...
>>>>> thanks
>>>>> messaggio news:g0uqvq$dvn$1@build.eclipse.org...
>>>>>> Tom
>>>>>>> as I want ...
>>>>>>> a wrong way ...
>>>>>>> called) ???
>>>>>>> thanks
>>>>>>> Kar
>>>>>>> SWT.NONE);
>>>>>>> @Override
>>>>>>> protected boolean
>>>>>>>> Tom
>>>>>>>> KarSc schrieb:
>>>>>>>>> Hi all
>>>>>>>>> any way to stop this behaviors and use F2 (via keylistener to
>>>>>>>>> fire the editing) or a rename action from the context menu?
>>>>>>>>> Thanks
>>>>>>>>> Kar
>>>>>>>> Tom Schindl
>>>>>>>> JFace-Committer
Previous Topic:listener on editor (close event)
Next Topic:Regarding plugin Signing info and certificate
Current Time: Fri Nov 07 20:58:17 EST 2025
Powered by FUDForum. Page generated in 0.04643 seconds
