Home » Eclipse Projects » Eclipse Platform » Plugin binary folder cause dependent plugins export to fail
Plugin binary folder cause dependent plugins export to fail [message #328255] |
Tue, 20 May 2008 07:53  |
Dear all,
I have plugin A which
- contains some classes in folder classes/
- expose them to other plugins using Export-Packages statement
- has the classes on its classpath as "class folder"
In the workspace, plugin B imports those classes and use them, no issue.
Now if I try to export plugin B as "deployable plugin", PDE fails to
build Plugin B because it cannot resolves binary classes for plugin A.
Plugin B export works only if binary classes are packaged as JAR in
plugin A.
I found a trace of the issue on news.eclipse.tools in 2001 :
http://dev.eclipse.org/newslists/news.eclipse.tools/msg03906 .html
I failed to find corresponding issue in Bugzilla, is it a known bug ?
Frederic
Re: Plugin binary folder cause dependent plugins export to fail [message #328259 is a reply to message #328258] |
Tue, 20 May 2008 08:40   |
Ed,
Thanks for your answer.
Plugin A is about exposing javax.transaction classes to other OSGi bundles.
classes are contained in javax/transaction and javax/transaction/xa folders
Basically yes plugin A list the classes folder in "bin.includes"
bin.includes = META-INF/,\
javax/
Plugin A .classpath file expose binary classes from its root:
<classpathentry exported="true" kind="lib" path=""/>
Am I missing something ?
Frederic
Ed Merks a écrit :
> Frederic,
> I wonder what your build.properties for A looks like? In particular, I
> wonder if you've properly specified to include the classes folder int he
> binary result.
> Frederic Conrotte wrote:
>> Dear all,
>> plugin A.
>> Frederic
Re: Plugin binary folder cause dependent plugins export to fail [message #328260 is a reply to message #328259] |
Tue, 20 May 2008 08:59   |
Frederic,
Comments below.
> Ed,
> bundles.
> folders
> javax/
Do you have a javax folder in your project's root? What does your
BundleClassPath looks like in the MANIFEST.MF?
Have you been fiddling directly with the project's Properties...? When
building plugins, all changes to the classpath should be done by editing
the MANIFEST.MF not via the project's properties..
> Frederic
> Ed Merks a écrit :
>> Frederic,
>> I wonder if you've properly specified to include the classes folder
>> int he binary result.
>>> Dear all,
>>> issue.
>>> plugin A.
>>> Frederic
Re: Plugin binary folder cause dependent plugins export to fail [message #328261 is a reply to message #328260] |
Tue, 20 May 2008 09:11   |
Ed,
Answers below as well.
FYI I'm using Eclipse 3.3.1
Frederic
Ed Merks a écrit :
> Frederic,
> Comments below.
>> Ed,
>> bundles.
>> folders
>> javax/
Yes I do
> What does your BundleClassPath looks like in the MANIFEST.MF?
It includes only the plugin's root (I think it could even be skipped as
it's added by default)
Manifest-Version: 1.0
Ant-Version: Apache Ant 1.7.0
Created-By: 1.5.0_12-b04 (Sun Microsystems Inc.)
Bundle-Name: Java Transaction API
Bundle-ClassPath: .
Bundle-ManifestVersion: 2
Bundle-SymbolicName: javax.transaction
Export-Package: javax.transaction;version="1.0.1",javax.transaction.xa
;version="1.0.1"
Bundle-Version: 1.0.1.200805201053
I used the Manifest editor.
>> Frederic
>> Ed Merks a écrit :
>>> Frederic,
>>>> Dear all,
>>>> issue.
>>>> plugin A.
>>>> Frederic
Re: Plugin binary folder cause dependent plugins export to fail [message #328302 is a reply to message #328266] |
Wed, 21 May 2008 04:04   |
Ed,
I should have done this from the beginning, show us the code ;)
I zipped the 2 plugins (A and B), you'll find them here:
http://www.covariance.lu/docs/eclipse.platform/Plugin_binary _folder_test.zip
the TransactionConsumer plugin imports classes from the
javax.transaction plugin.
When exporting the TransactionConsumer plugin, PDE (of Eclipse v3.3.1)
produces a logs.zip containing the following compiling error:
# 21/05/08 9:52:55 CEST
# Eclipse Java Compiler 0.780_R33x, 3.3.1, Copyright IBM Corp 2000,
2007. All rights reserved.
1. ERROR in
(...snip...)\TransactionConsumer\src\org\example\Transaction Consumer.java
(at line 3)
import javax.transaction.TransactionManager;
The import javax.transaction.TransactionManager cannot be resolved
2. ERROR in
(at line 7)
public TransactionConsumer(TransactionManager aTransactionManager) {
TransactionManager cannot be resolved to a type
2 problems (2 errors)
Though in the workspace, TransactionConsumer.java compiles.
Frederic
Ed Merks a écrit :
> Frederic,
> I expect your .classpath to look like this:
> <classpath>
> <classpathentry kind="src" path="src/"/>
> <classpathentry kind="con"
> path=" org.eclipse.jdt.launching.JRE_CONTAINER/org.eclipse.jdt.inte rnal.debug.ui.launcher.StandardVMType/J2SE-1.5 "/>
> path="org.eclipse.pde.core.requiredPlugins"/>
> <classpathentry kind="output" path="bin"/>
> </classpath>
> For us the build.properties looks like this:
> bin.includes = about.html,\
> plugin.properties,\
> plugin.xml,\
> model/,\
> META-INF/,\
> schema/
> src.includes = about.html
> source.. = src/
> output.. = bin/
> exclude.. = **/doc-files/**
> I'm confused about that "classes" folder you mentioned. So I get the
> sense that something fishy is going on with your classpath related to
> this javax thing. I think you should be specifying that it's part of
> the output.. rather than what you've done...
>> Ed,
>> Frederic
>> Ed Merks a écrit :
>>> Frederic,
>>> Comments below.
>>>> Ed,
>>>> bundles.
>>>> folders
>>>> javax/
>> Yes I do
>> as it's added by default)
>> Bundle-ClassPath: .
>> ;version="1.0.1"
>>> When building plugins, all changes to the classpath should be done by
>>> editing the MANIFEST.MF not via the project's properties..
>>>> Frederic
>>>> Ed Merks a écrit :
>>>>> Frederic,
>>>>> particular, I wonder if you've properly specified to include the
>>>>> classes folder int he binary result.
>>>>>> Dear all,
>>>>>> issue.
>>>>>> to build Plugin B because it cannot resolves binary classes for
>>>>>> plugin A.
>>>>>> in plugin A.
>>>>>> Frederic
Re: Plugin binary folder cause dependent plugins export to fail [message #328327 is a reply to message #328302] |
Wed, 21 May 2008 12:02   |
Frederic,
It sounds like you're using a different JDK in that case. Not sure how
to control that...
> Ed,
> 1. ERROR in
> (at line 3)
> 2. ERROR in
> (at line 7)
> Frederic
> Ed Merks a écrit :
>> Frederic,
>> <?xml version="1.0" encoding="UTF-8"?>
>> <classpath>
>> </classpath>
>> plugin.properties,\
>> plugin.xml,\
>> model/,\
>> META-INF/,\
>> schema/
>> source.. = src/
>> output.. = bin/
>> the sense that something fishy is going on with your classpath
>> related to this javax thing. I think you should be specifying that
>> it's part of the output.. rather than what you've done...
>>> Ed,
>>> Frederic
>>> Ed Merks a écrit :
>>>> Frederic,
>>>> Comments below.
>>>>> Ed,
>>>>> bundles.
>>>>> javax/
>>> Yes I do
>>> Bundle-ClassPath: .
>>> ;version="1.0.1"
>>>> by editing the MANIFEST.MF not via the project's properties..
>>>>> Frederic
>>>>> Ed Merks a écrit :
>>>>>> Frederic,
>>>>>>> Dear all,
>>>>>>> no issue.
>>>>>>> fails to build Plugin B because it cannot resolves binary
>>>>>>> in plugin A.
>>>>>>> bug ?
>>>>>>> Frederic
Current Time: Wed Jul 16 05:55:55 EDT 2025
Powered by FUDForum. Page generated in 0.10304 seconds
