Home » Eclipse Projects » Eclipse Platform » Regex for filenames in plugin.xml
Regex for filenames in plugin.xml [message #328253] Tue, 20 May 2008 05:59 Go to next message
Originally posted by: _onni_.telenet.be
Hello
I've developed a visual XML editor for different XML files with the same
structure. At this moment I attach the editor by placing "*.xml" as the
value of the filenames within plugin.xml and it works fine.
All the files that have to use the editor by default begin with
description and are followed by a digit. For example description1,
description27,...
Is there a way to use a regex in the filenames attribute in plugin.xml so
that only the files according to the given expression will have the editor
by default?
Kind regards
Xnni
Re: Regex for filenames in plugin.xml [message #328329 is a reply to message #328253] Wed, 21 May 2008 12:44 Go to previous message
Xnni wrote:
> Hello
> same structure. At this moment I attach the editor by placing "*.xml"
> as the value of the filenames within plugin.xml and it works fine.
> description27,...
> so that only the files according to the given expression will have the
> editor by default?
No, that's not possible. If your XML has some specific markup then you
could register your own content type that uses a content describer to
find matching files.
Dani
> Kind regards
> Xnni
Previous Topic:Job Problem Occurred Dialog
Next Topic:eclipse hangs when opening java files
Current Time: Fri Jul 18 23:00:37 EDT 2025
Powered by FUDForum. Page generated in 0.25587 seconds
