Home » Eclipse Projects » Eclipse Platform » How to prevent an editor from closing?
How to prevent an editor from closing? [message #328217] Mon, 19 May 2008 04:05 Go to next message
Originally posted by: fuxianghit.gmail.com
Hi All,
My project requires to show a confirm dialog after the user clicking on
the 'x' button (or select File -> Close, or File -> Close All,, or
whatever) to close the editor, prompts for "Continue" or "Cancel" the
closing operation, and if the user selects cancel, I would stop eclipse
from closing this editor.
I have tracked to org.eclipse.ui.internal.SaveablesList where the
standard eclipse closing operation will show a prompt for saving dialog,
but it's impossible to add anything here. And unfortunately I didn't find
any other information on this issue after digging into those docs I can
get. Could you please help me out? Thanks a lot!
Shone
Re: How to prevent an editor from closing? [message #328404 is a reply to message #328217] Fri, 23 May 2008 19:06 Go to previous message
Shone,
Have your editor implemented org.eclipse.ui.ISaveablePart2.
David Kyle
http://richclientplatform.blogspot.com/
Previous Topic:Separators in org.eclipse.ui.popupMenus
Next Topic:How to bind Tab in plugin.xml for an editor.
Current Time: Sun Aug 31 20:16:45 EDT 2025
Powered by FUDForum. Page generated in 0.11907 seconds
