Home » Eclipse Projects » Eclipse Platform » Problem with JDT or CDT in Ganymede M7
Problem with JDT or CDT in Ganymede M7 [message #328170] Fri, 16 May 2008 05:00 Go to next message
Originally posted by: divis1969.mail.ru
I've downloaded M7 packages and unpacked into the clean directory (I've
tried both -cpp- and -java- packages separately).
When Eclipse starts for the first time it is showing splash screen for a
long time. After that, it is asking me for workspace location, and when I
provide it (some clean directory) it starts but neither CDT nor JDT
installed.
What is strange, I cannot see Help > Software Updates > Manage
Configuration referenced in readme/readme_eclispe.html.
Under Installed Software I can see only "Eclipse Platform".
So my question is what I'm doing wrong?
Perhaps, some lines from log will help. At least I can suspect that
initial start is taking so long because of network problem (I'm sitting
behind a proxy):
!MESSAGE Unable to load repository:
http://download.eclipse.org/tools/mylyn/update/e3.4
Caused by: java.net.ConnectException: Connection timed out: connect
!MESSAGE An error occurred while collecting items to be installed
!SUBENTRY 1 org.eclipse.equinox.p2.artifact.repository 4 0 2008-05-16
12:48:18.155
!MESSAGE No repository found containing:
javax.xml/osgi.bundle/1.3.4.v2008041723
Dmitry
Re: Problem with JDT or CDT in Ganymede M7 [message #328177 is a reply to message #328170] Fri, 16 May 2008 08:14 Go to previous message
I've found that I can manually install CDT using
http://download.eclipse.org/tools/cdt/releases/ganymede (this URL was
pre-provisioned in -cpp- package)
At the same time, I still cannot install JDT since
http://download.eclipse.org/eclipse/updates/3.4 is not valid update site
(this URL is also pre-provisioned).
So, I'm wondering, is there any update site I can use for JDT (Ganymede
M7) installation?
Previous Topic:How to hight words in table viewer
Next Topic:help -- cannot update pde incubator visualization plugin
Current Time: Thu Oct 23 06:24:27 EDT 2025
Powered by FUDForum. Page generated in 0.05184 seconds
