| Vertical Alignment Of Sections [message #328138] |
Thu, 15 May 2008 03:17  |
I've a Section which I tell to align vertically.
Section section = toolkit.createSection(form.getBody(), Section.TITLE_BAR
| Section.FOCUS_TITLE | Section.EXPANDED | Section.TWISTIE);
TableWrapData data = new TableWrapData(TableWrapData.FILL);
data.align = TableWrapData.FILL;
data.grabVertical = true;
section.setLayoutData(data);
When adding controls into the sections client, the sections height is
always just as high as the accumulated content of its client.
Sections covering all available vertical space wether there content
requires it or not can be seen in the plugin manifeft editor ('Rutime' or
'Extensions' Tab).
My question is, how can I make my section as high as the FormEditor
(ManagedForm), just as it can be seen in the plugin manifest editor?
Thanks!
| Re: Vertical Alignment Of Sections [message #328145 is a reply to message #328138] |
Thu, 15 May 2008 09:43  |
Jan Kohnert wrote:
> Hello,
> Section.TITLE_BAR | Section.FOCUS_TITLE | Section.EXPANDED |
> Section.TWISTIE);
> or 'Extensions' Tab).
The TableWrapLayout isn't going to stretch the section vertically, only
horizontally. To get sections that fill the page vertically you should
use a different layout, perhaps FillLayout (the simplest) or GridLayout
or FormLayout.
Hope this helps,
Eric
FUDForum. Page generated in 0.02712 seconds
