Home » Eclipse Projects » Eclipse Platform » Project name not used on importing existing project
Project name not used on importing existing project [message #328125] Wed, 14 May 2008 14:45 Go to next message
Using Eclipse 3.4M7 I've noticed that when I attempt to import my existing
projects (created by Maven) that if the project name does not match the
directory that the directory name is used instead of the project name.
For example:
Directory MyEclipse\projects\project1\config
contains a java project with a project name proj1-config
Directory MyEclipse\projects\project2\config
contains a java project with a project name proj2-config
When attempting to import the existing projects starting at the root of
MyEclipse , the two projects get picked up but their names are displayed
in the dialog as
config (proj1-config)
config (proj2-config)
Attempting to import the projects Eclipse than has issues importing
projects due to 2 projects with the same name.
The above functionality seemed to get introduced around 3.4M5. Is there
an option I'm missing or is this a bug?
Re: Project name not used on importing existing project [message #328128 is a reply to message #328125] Wed, 14 May 2008 16:56 Go to previous message
> existing projects (created by Maven) that if the project name does not
> match the directory that the directory name is used instead of the
> project name.
> For example:
> in the dialog as
See this bug report (and the ones it links to):
https://bugs.eclipse.org/bugs/show_bug.cgi?id=225754
Hope this helps,
Eric
Previous Topic:how to prevent statusbar resize
Next Topic:How to make my hyperlinks work in console?
Current Time: Fri Nov 07 04:03:07 EST 2025
Powered by FUDForum. Page generated in 0.02520 seconds
