Import team project set outside the workspace [message #328081] |
Tue, 13 May 2008 15:18  |
Originally posted by: will.houck.gmail.com
It seems that team project sets (.psf files) always import the project
list to the same directory as the workspace. Is it possible specify an
alternate location as you can with new projects, imported projects and the
checkout wizard?
I tried manually modifying the psf file to ref an alternate location but
as expected, this did not work.
Will
Re: Import team project set outside the workspace [message #328120 is a reply to message #328118] |
Wed, 14 May 2008 10:16  |
Michael,
But I'm so busy and you have copious spare time. :-P
I helped provide a few patches to PDE last week, so maybe I'll take a
kick at the CVS can one of these days too. Be careful what you ask for!
Michael Valenta wrote:
> Ed and Will,
> The best workaround is to provide a patch that adds a prompt for an
> alternate parent folder as described in the bug report ;-)
> Michael
> Ed Merks wrote:
>> Will,
>> I've not figured out a workaround. :-(
>> Will wrote:
>>> Ed, thanks for the info. Any suggested work arounds? I've
>>> experimented with ant tasks leveraging projectImport which solves
>>> the issue of alternate project locations, but then I still have to
>>> manually enable cvs for each project via menu option Team/Projecct
>>> Share.
FUDForum. Page generated in 0.03269 seconds
