Home » Eclipse Projects » Eclipse Platform » How to show view in Action.run( )
How to show view in Action.run( ) [message #327986] Mon, 12 May 2008 00:39 Go to next message
Hi Alles,
I am new and wondering whether I could get help here. I have an Action.
I want that by Clicking it would cause several instances of a View to
show. However, using IWorkbenchPage.showView(...) did not show the view
content (e.g., a label or an image). The program seemed to skip it and
continue to run the code after the showView() statement (e.g.,
System.out.println(...) or Thread.sleep(...)). If I inserted a
MessageBox after the showView() statement. The IWorkbenchPage.showView()
then displayed the view. Why do I need a MessageBox to have the view
shown? Can I show the view without the MessageBox? Any help please?
Ben
Re: How to show view in Action.run( ) [message #328658 is a reply to message #327986] Fri, 30 May 2008 11:13 Go to previous message
Depending on what you put there ... i.e. if you did a showView(*) and
then a Thread.sleep(*), it will never show up. You've blocked the UI
thread!
you would need to showView(*) and then exit your run(*) method.
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Previous Topic:Determining when the project was refreshed the last time
Next Topic:Expressions definition iterate/or condition
Current Time: Sun Aug 31 01:07:14 EDT 2025
Powered by FUDForum. Page generated in 0.03750 seconds
