Home » Eclipse Projects » Eclipse Platform » Weird SWTException
Weird SWTException [message #327929] Thu, 08 May 2008 11:44 Go to next message
Originally posted by: brianf.sybase.com
Hi all...
I'm working with the 3.4 M7 platform build and we're getting this strange
error from DTP when we delete a profile that's connected. What's weird is
that this code hasn't changed and it works just fine on 3.3.2.
There's absolutely no additional information I can provide, otherwise I'd be
debugging this one further myself.
Has anyone else seen this bizarro behavior anywhere else with the 3.4 M7
milestone? I'm plum out of ideas.
It's BZ231008 if anyone is interested.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=231008
Thanks in advance
--Fitz (aka Brian Fitzpatrick)
Data Tools Project PMC Lead
Data Tools Project Connectivity Sub-project Lead
Sr. Software Engineer
Sybase, Inc.
!ENTRY org.eclipse.ui 4 0 2008-05-08 09:15:55.915
!MESSAGE Unhandled event loop exception
!STACK 0
org.eclipse.swt.SWTException: Graphic is disposed
at org.eclipse.swt.SWT.error(SWT.java:3773)
at org.eclipse.swt.SWT.error(SWT.java:3691)
at org.eclipse.swt.SWT.error(SWT.java:3662)
at org.eclipse.swt.graphics.Image.getImageData(Image.java:1190)
at org.eclipse.swt.internal.ImageList.set(ImageList.java:401)
at org.eclipse.swt.internal.ImageList.add(ImageList.java:66)
at org.eclipse.swt.widgets.Tree.imageIndex(Tree.java:3607)
at org.eclipse.swt.widgets.Tree.wmNotifyChild(Tree.java:7019)
at org.eclipse.swt.widgets.Control.wmNotify(Control.java:4713)
at org.eclipse.swt.widgets.Composite.wmNotify(Composite.java:17 56)
at org.eclipse.swt.widgets.Control.WM_NOTIFY(Control.java:4343)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3836 )
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4500 )
at org.eclipse.swt.internal.win32.OS.CallWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.CallWindowProc(OS.java:226 0)
at org.eclipse.swt.widgets.Tree.callWindowProc(Tree.java:1521)
at org.eclipse.swt.widgets.Tree.WM_PAINT(Tree.java:6673)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3837 )
at org.eclipse.swt.widgets.Tree.windowProc(Tree.java:5703)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4487 )
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:23 46)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3379)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2394)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2358)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 10)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:494)
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:489)
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:112)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:379)
Re: Weird SWTException [message #327955 is a reply to message #327929] Fri, 09 May 2008 09:30 Go to previous messageGo to next message
Hi Brian,
It looks like an Image has been dispose()d while it's still set as a
TreeItem's image in a non-disposed Tree. If you put a breakpoint where the
exception occurs then you can see in the stack's
org.eclipse.swt.widgets.Tree.wmNotifyChild(...) method which item has the
disposed image, and hopefully from there figure out how this image got
disposed too early.
Grant
"Brian Fitzpatrick" <brianf@sybase.com> wrote in message
news:fvv748$urp$1@build.eclipse.org...
> Hi all...
be
> Thanks in advance
> Sybase, Inc.
> !STACK 0
> at
> at
> at
java:112)
> at
193)
> at
> at
pLauncher.java:79)
> at
> at
Re: Weird SWTException [message #327959 is a reply to message #327955] Fri, 09 May 2008 10:05 Go to previous message
Thanks Grant. I appreciate the help. I'll see if that works.
--Fitz
"Grant Gayed" <grant_gayed@ca.ibm.com> wrote in message
news:g01jlv$1ph$1@build.eclipse.org...
> Hi Brian,
> the
> disposed too early.
> Grant
>> Hi all...
> be
>> Thanks in advance
>> Sybase, Inc.
>> !STACK 0
>> at
>> at
>> at
> java:112)
>> at
> 193)
>> at
>> at
> pLauncher.java:79)
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
Previous Topic:how to be notified of Select All action selection in Variables View
Next Topic:Ganymede: Platform Plugin Developer Guide?
Current Time: Wed Nov 05 14:46:21 EST 2025
Powered by FUDForum. Page generated in 0.06305 seconds
