Home » Eclipse Projects » Eclipse Platform » Running Plug-ins for Plug-in creation
Running Plug-ins for Plug-in creation [message #327923] Thu, 08 May 2008 10:00 Go to next message
I don't know how to explain my problem best, though I guess other people
must have had the same problem.
I want to create a library eclipse plug-in with classes that can later be
used by different plugins.
Assume I have a library workspace with the library plug-open in as
project. I would like to run / debug this plug-in from there, and in the
strated eclipse environment, I would like to create a new plugin that
depends, on the library plug-in.
Right now, in order to do so, I have to deploy the library plug-in and
unzip it into the plug-ins folder of a different environment, but that's
cumbersome to me. Is there some way I can run a plug-in such that it is
visible for plug-in projects in the target environment?
Re: Running Plug-ins for Plug-in creation [message #327926 is a reply to message #327923] Thu, 08 May 2008 10:19 Go to previous messageGo to next message
As far as I know you have 2 choices:
1. If you want to run a normal Eclipse, you can either have the project in
your workspace and reference it or you can deploy it to the plugins folder.
2. In a runtime workbench, you can use projects from your workspace like
they were deployed plugins.
"Thibault" <thibault.kruse@gmx.de> wrote in message
news:52a48cdb7c0c7c9b8cad14088d40663f$1@www.eclipse.org...
Re: Running Plug-ins for Plug-in creation [message #327928 is a reply to message #327923] Thu, 08 May 2008 10:56 Go to previous messageGo to next message
Are you using something like EMF?
In 3.4M7, PDE added support for 'target weaving' which pretty much
translates into supporting the compilation of launching workspace plug-ins.
http://download.eclipse.org/eclipse/downloads/drops/S-3.4M7- 200805020100/eclipse-news-M7.html
However, this only applies if you're using plug-ins.
~ Chris
Re: Running Plug-ins for Plug-in creation [message #327944 is a reply to message #327926] Fri, 09 May 2008 03:48 Go to previous messageGo to next message
Hi Felix,
It seems to me I can use my plugins in my runtime workspace, But I cannot
refer to them from plug-in projects in my runtime workspace.
For me it seems I cannot, since if in my runtime workspace I create a new
plugin, I cannot set a dependency to a plugin in my original workspace.
I need to set such dependencies from runtime workspace to plug-ins in the
original workspace, I I also need to reference classes contained in
plugins in the original workspace.
Re: Running Plug-ins for Plug-in creation [message #327945 is a reply to message #327928] Fri, 09 May 2008 03:51 Go to previous messageGo to next message
Hi Chris,
it seems that that is part of what I need, so i also understand this is
not possible prior to 3.4 M7.
Re: Running Plug-ins for Plug-in creation [message #327964 is a reply to message #327945] Fri, 09 May 2008 15:30 Go to previous message
Thibault wrote:
> Hi Chris,
Correct, this was a very long and outstanding issue as JDT needed to
support external class folders for this to happen along with PDE
supporting target weaving.
See this bug for more information:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=109137
~ Chris
Previous Topic:Ganymede: Platform Plugin Developer Guide?
Next Topic:Where to call a validation mechanism in an editor?
Current Time: Tue Jul 22 04:41:26 EDT 2025
Powered by FUDForum. Page generated in 0.06514 seconds
