Home » Eclipse Projects » Eclipse Platform » Using F3 key with and without JDT
Using F3 key with and without JDT [message #327895] Wed, 07 May 2008 13:35 Go to next message
I have written a graphical editor, and now I am wondering how I could use
the F3 key to open source files from a context menu within that editor. The
JDT is has defined this key already, so I can use their command's
definitionId when I define my action in the org.eclipse.ui.popupMenus
extension point. The problem is that my editor should be independent of the
JDT. When I try to define my own command and key to use when JDT is not
around, they collide with the JDT's definitions when JDT is there. Is there
any way I can resolve this and have my editor work with and without JDT?
Thanks, Felix
Re: Using F3 key with and without JDT [message #327910 is a reply to message #327895] Thu, 08 May 2008 05:26 Go to previous messageGo to next message
Why do they collide? Make sure not to use the same ID when defining the
command.
Dani
> Is there
> Thanks, Felix
Re: Using F3 key with and without JDT [message #327924 is a reply to message #327910] Thu, 08 May 2008 10:14 Go to previous messageGo to next message
They collide because the F3 key binding has already been defined by the JDT.
This has nothing to do with the commands themselves. The problem is that
with JDT present, I need to retarget the F3 key binding, while without JDT I
need to define the key binding myself.
"Daniel Megert" <daniel_megert@ch.ibm.com> wrote in message
news:fvuh0e$jqh$2@build.eclipse.org...
>> The JDT is has defined this key already, so I can use their command's
>> the JDT. When I try to define my own command and key to use when JDT is
>> not around, they collide with the JDT's definitions when JDT is there.
> command.
> Dani
>> Is there any way I can resolve this and have my editor work with and
>> without JDT?
>> Thanks, Felix
Re: Using F3 key with and without JDT [message #327946 is a reply to message #327924] Fri, 09 May 2008 05:05 Go to previous messageGo to next message
Simply define your own command (in different scope than JDT) and key
binding. Then always retarget your command.
Dani
>> command.
>> Dani
>>> without JDT?
>>> Thanks, Felix
Re: Using F3 key with and without JDT [message #328034 is a reply to message #327946] Mon, 12 May 2008 16:47 Go to previous message
Daniel Megert wrote [2008-05-09 11:05]:
>> the JDT. This has nothing to do with the commands themselves. The
>> problem is that with JDT present, I need to retarget the F3 key
>> binding, while without JDT I need to define the key binding myself.
> Dani
F3 is bound in the "In Window" scope to the command by JDT. This is not
a proper solution for a multilanguage IDE (it should be in Platform or
bound to Java scopes).
Felix, you have to bind your command in a more special scope for your
language, then it overwrites the binding of JDT (as example you can look
in definitions of CDT).
Teddy
>>>> could use the F3 key to open source files from a context menu within
>>>> that editor. The JDT is has defined this key already, so I can use
>>>> their command's definitionId when I define my action in the
>>>> org.eclipse.ui.popupMenus extension point. The problem is that my
>>>> editor should be independent of the JDT. When I try to define my own
>>>> command and key to use when JDT is not around, they collide with the
>>> the command.
>>> Dani
>>>> and without JDT?
>>>> Thanks, Felix
Previous Topic:Suggestion: Syntax Coloring Eclipse 3.4
Next Topic:infocenter as a war
Current Time: Sun Nov 09 09:43:02 EST 2025
Powered by FUDForum. Page generated in 0.03249 seconds
