Home » Eclipse Projects » Eclipse Platform » Ganymede IHandler2/AbstractHandler execute() method not recognized in @Override
Ganymede IHandler2/AbstractHandler execute() method not recognized in @Override [message #327872] Tue, 06 May 2008 18:53 Go to next message
I'm trying to convert some 3.3 code to Ganymede/3.4
I have a class (AnalysisDropdownHandler) that extends
org.eclipse.core.commands.AbstractHandler, which in 3.3 implements IHandler.
In 3.4, AbstractHandler instead implements IHandler2, which extends
IHandler.
My class has an @Override annotation on its execute() method:
public Object execute(ExecutionEvent event) throws
ExecutionException { ...}
execute() is (still) in the IHandler interface.
So, why does the compiler give me an error on my code?
If I hover over the error I get:
Multiple markers at this line
- implements org.eclipse.core.commands.IHandler.execute
- The method execute(ExecutionEvent) of type
AnalysisDropdownHandler must override a superclass method
Am I missing something obvious?
....Beth Tibbitts
Re: Ganymede IHandler2/AbstractHandler execute() method not recognized in @Override [message #327874 is a reply to message #327872] Tue, 06 May 2008 19:25 Go to previous messageGo to next message
Beth,
@Override has different meaning in Java 5.0 verses Java 6.0. What
source compatibility setting are you using when compiling? For Java
5.0, @Override must override a base class' implementation but for Java
6.0, it's sufficient that the method implement a declared interface
method (more like @Implements) rather than literally an override of a
base class method.
> IHandler.
> IHandler.
> @Override
> ...Beth Tibbitts
Re: Ganymede IHandler2/AbstractHandler execute() method not recognized in @Override [message #327887 is a reply to message #327874] Wed, 07 May 2008 09:37 Go to previous messageGo to next message
Thanks, Ed.
I'm using the default compatibility settings (I think) in both Eclipse
3.3 and 3.4.
In 3.4 preferences, Java > Compiler is set to use default compliance
settings, which is 1.5.
In 3.3 it's set to default compliance setting, which is 5.0 (Funny that
they would change the terminology)
The only way i see to get around this is to remove the @Overrides
annotation??? That doesn't seem right. If the execute() method had
truly gone away in the underlying class/interfaces, it would have been
crucial to point me to that error. In my case it doesn't seem to be an
error.
....Beth
Ed Merks wrote:
> Beth,
> base class method.
>> IHandler.
>> IHandler.
>> @Override
>> ...Beth Tibbitts
Re: Ganymede IHandler2/AbstractHandler execute() method not recognized in @Override [message #327891 is a reply to message #327887] Wed, 07 May 2008 09:58 Go to previous messageGo to next message
The explanation is in https://bugs.eclipse.org/bugs/show_bug.cgi?id=230063
In fact this was a bug in Eclipse 3.3 there's never been a method in the
AbstractHandler and Eclipse wrongly reported it and hence added an
@Override :-)
Tom
Beth Tibbitts schrieb:
> Thanks, Ed.
> 3.3 and 3.4.
> error.
> ...Beth
> Ed Merks wrote:
>> Beth,
>> base class method.
>>> IHandler.
>>> IHandler.
>>> @Override
>>> ...Beth Tibbitts
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: Ganymede IHandler2/AbstractHandler execute() method not recognized in @Override [message #327900 is a reply to message #327891] Wed, 07 May 2008 17:50 Go to previous message
Thanks Tom.
I've removed the @Override annotation and things work fine.
....Beth
> @Override :-)
> Tom
>> Thanks, Ed.
>> 3.3 and 3.4.
>> that they would change the terminology)
>> an error.
>> ...Beth
>> Ed Merks wrote:
>>> Beth,
>>> Java 6.0, it's sufficient that the method implement a declared
>>> interface method (more like @Implements) rather than literally an
>>> override of a base class method.
>>>> IHandler.
>>>> IHandler.
>>>> @Override
>>>> ...Beth Tibbitts
Previous Topic:Running ant task within Eclipse
Next Topic:eclipse 3.4M6 won't run from NFS disk
Current Time: Thu Nov 20 04:46:13 EST 2025
Powered by FUDForum. Page generated in 0.05778 seconds
