Home » Eclipse Projects » Eclipse Platform » The JAR of this class file belongs to contain 'Plug-in Dependencies' which does not allow modificati
The JAR of this class file belongs to contain 'Plug-in Dependencies' which does not allow modificati [message #327860] Tue, 06 May 2008 13:34 Go to next message
I get the subject message when I try to look at the source for
org.eclipse.core.resources.IContainer.
How can I attach the source so eclipse just uses it when I inspect the
code with debugger or source declaration navigation?
John.
Re: The JAR of this class file belongs to contain 'Plug-in Dependencies' which does not allow modifi [message #327862 is a reply to message #327860] Tue, 06 May 2008 14:35 Go to previous messageGo to next message
You have to install the "org.eclipse.platform.source" plugin. It (and
lots of other source) is included in the "Eclipse for RCP/Plug-in
Developers" and "Eclipse Classic" packages on the download page.
If you installed one of the other packages, I don't know of an easy way
to get the source features into it. What I've done in the past is to
install the RCP/Plugin package and then grab all the source features and
plugins that I needed from that and copy them into my other Eclipse
installation.
Hope this helps,
Eric
Re: The JAR of this class file belongs to contain 'Plug-in Dependencies' which does not allow modifi [message #327869 is a reply to message #327862] Tue, 06 May 2008 16:58 Go to previous messageGo to next message
> installation.
> Hope this helps,
> Eric
Thanks Eric. I'm running Ganymede M6 which seems to be 3.3.0. Can't I
just checkout the code from cvs? Surely there is a cvs tag for the
builds that go in to Ganymede, so I should be able to get the exact
source with one cvs checkout and one config to eclipse....
John.
Re: The JAR of this class file belongs to contain 'Plug-in Dependencies' which does not allow modifi [message #327870 is a reply to message #327860] Tue, 06 May 2008 17:11 Go to previous messageGo to next message
So start with http://www.eclipse.org/downloads/ and select "Source
Code". You end up on http://wiki.eclipse.org/index.php/CVS_Howto. There
you can read:
....use the source included in the Eclipse SDK download. The download
contains source zips which can be attached to jars in the SDK's Java
tooling and used for browsing and debugging.
The link on Eclipse SDK is ... any guesses... yes:
http://www.eclipse.org/downloads/.
Go to "So start with..."
John.
Re: The JAR of this class file belongs to contain 'Plug-in Dependencies' which does not allow modifi [message #327875 is a reply to message #327860] Tue, 06 May 2008 20:39 Go to previous messageGo to next message
At least in Ganymede, the answer is:
Plugin Devel Perspective
Plugin View
Select plugin, Right click->Import As->BinaryProjectWithLinkedContent.
John
Re: The JAR of this class file belongs to contain 'Plug-in Dependencies' which does not allow modifi [message #327888 is a reply to message #327869] Wed, 07 May 2008 09:38 Go to previous messageGo to next message
>>> the code with debugger or source declaration navigation?
>> way to get the source features into it. What I've done in the past is
>> to install the RCP/Plugin package and then grab all the source
>> features and plugins that I needed from that and copy them into my
>> other Eclipse installation.
>> Hope this helps,
>> Eric
Ganymede is Eclipse 3.4. And yes, if you are willing to go the CVS route
you can get the source for any plugin you want (as a project in your
workspace). The trick is finding the correct repository path for the
plugin(s) you are interested in.
There is a drawback of this approach in that it clutters up your
workspace with the plugin source project(s). If you install the source
as plugin(s) into your Eclipse there is no manifestation of it as a
project in your workspace.
Of course, having the source as a project is kind of nice if you want to
experiment with changing things; and it is required if you are going to
submit a patch to correct or change something in an existing plugin.
Eric
Re: The JAR of this class file belongs to contain 'Plug-in Dependencies' which does not allow modifi [message #327902 is a reply to message #327875] Wed, 07 May 2008 20:00 Go to previous message
> Plugin View
Except there is a bug somewhere. In my efforts to solve this problem,
somewhere in the Eclipse UI I put the string
F:\ganymede\src\org.eclipse.core.resources\src
Now I can't use the debugger because I get massive numbers of error
Error
Wed May 07 16:45:19 PDT 2008
Unable to access archive F:\ganymede\src\org.eclipse.core.resources\src
java.util.zip.ZipException: Access is denied
Any hints?
John.
Previous Topic:eclipse 3.4M6 won't run from NFS disk
Next Topic:Setting size of window created by PlatformUI.getWorkbench().openWorkbenchWindow
Current Time: Tue Nov 18 16:07:37 EST 2025
Powered by FUDForum. Page generated in 0.05974 seconds
