Home » Eclipse Projects » Eclipse Platform » how to be notified of Select All action selection in Variables View
how to be notified of Select All action selection in Variables View [message #327853] Tue, 06 May 2008 05:40 Go to next message
I have added a couple of actions in Variables View context menu and I
enable or disable them depending upon the selection in Variables View.
Problem is that when "Select All" action is selected, all variables get
selected but I do not get any selection notification hence I can not
properly enable or disable my actions. I am using Eclipse 3.3.1.1.
org.eclipse.debug.internal.ui.actions.SelectAllAction seems to call tree’s
selectAll() but does not notify selection listeners.
Could anyone please suggest what I should do to be notified when variables
are selected as a response to "Select All" action selection in Variables
View.
Note: I do not have the option to use newer versions of Eclipse.
Thanks.
Re: how to be notified of Select All action selection in Variables View [message #327922 is a reply to message #327853] Thu, 08 May 2008 09:12 Go to previous messageGo to next message
> View.
> Thanks.
Any help will be much appreciated.
Re: how to be notified of Select All action selection in Variables View [message #327957 is a reply to message #327853] Fri, 09 May 2008 09:41 Go to previous message
If the select all action is not sending out a selection changed event,
you need to open a bug at https://bugs.eclipse.org/bugs/ Eclipse
Platform Debug. Please include your usecase and how the results are
incorrect.
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Previous Topic:BidiUtil.isBidiPlatform() - Version display BiDi question
Next Topic:Weird SWTException
Current Time: Mon Nov 17 19:14:12 EST 2025
Powered by FUDForum. Page generated in 0.04400 seconds
