Home » Eclipse Projects » Eclipse Platform » Showing CTabItem in CTabFolder
Showing CTabItem in CTabFolder [message #327813] Sat, 03 May 2008 19:38 Go to next message
Originally posted by: micha.bgl.gmx.de
Hi there,
I have a CTabFolder with two tabs. How I can force CTabFolder to show the
cTabItem I want to let show in my View ? I tried
ctabfolder.showItem(ctabitem). But it didn't work. nothing changed. Thanks
for responding.
regards,
micha
Re: Showing CTabItem in CTabFolder [message #327814 is a reply to message #327813] Sun, 04 May 2008 04:09 Go to previous messageGo to next message
Originally posted by: automatic.javalobby.org
this should solve your problem:
yourTabFolder.showItem(yourItem);
yourTabFolder.setSelection(yourItem);
With kind regards
Marcel
Re: Showing CTabItem in CTabFolder [message #327817 is a reply to message #327814] Sun, 04 May 2008 05:54 Go to previous messageGo to next message
It works fine. Thanks for the fast response. But I wondered why
showItem(myItem) doesn't work without setSelection, because in the method
setSelection(int index) the method showItem is called.
"Marcel" <automatic@javalobby.org> schrieb im Newsbeitrag
news:3346048.4731209888623259.JavaMail.root@cp1.dzone.com...
> Hello,
> With kind regards
> Marcel
Re: Showing CTabItem in CTabFolder [message #327833 is a reply to message #327817] Mon, 05 May 2008 09:56 Go to previous message
You only need to call setSelection(...). The purpose of showItem(...) is to
ensure that an item's tab appears in the row of tabs at the top (ie.- is not
scrolled off of the right), not to show its contents.
Grant
"Michael Weber" <micha.bgl@gmx.de> wrote in message
news:fvk14t$h1c$1@build.eclipse.org...
> > Hello,
> > With kind regards
> > Marcel
Previous Topic:Where is "Manage Configuration" gone in 3.4M6
Next Topic:Perspective ordering not kept be workbench
Current Time: Sat Nov 01 12:36:04 EDT 2025
Powered by FUDForum. Page generated in 0.04458 seconds
