Home » Eclipse Projects » Eclipse Platform » Where is "Manage Configuration" gone in 3.4M6
Where is "Manage Configuration" gone in 3.4M6 [message #327761] Wed, 30 April 2008 15:36 Go to next message
Originally posted by: pschoenb.gmx.de
I just updated to Eclipse 3.4M6 and I am missing the menu action "Help >
Software Updates > Manage Configuration". I can access the corresponding
dialog via a keyboard shortcut. But where is the menu entry gone?
Patrick
Re: Where is "Manage Configuration" gone in 3.4M6 [message #327762 is a reply to message #327761] Wed, 30 April 2008 18:30 Go to previous messageGo to next message
Originally posted by: phillipus.nowhere.net
Patrick Schoenbach wrote:
Good question. It's the same in the latest Integration build.
Re: Where is "Manage Configuration" gone in 3.4M6 [message #327769 is a reply to message #327761] Wed, 30 April 2008 19:09 Go to previous messageGo to next message
That functionality has been replaced by the new p2 component, which is
intended to make updating and config management a lot better. See
http://wiki.eclipse.org/Equinox_p2
Hope this helps,
Eric
Re: Where is "Manage Configuration" gone in 3.4M6 [message #327774 is a reply to message #327761] Wed, 30 April 2008 19:30 Go to previous messageGo to next message
You know that Manage Configuration has been replaced by p2 and the new
software updates UI.
But you can get it back, go to Window>Preferences>General>Capabilities
and include "Classic Update"
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: Where is "Manage Configuration" gone in 3.4M6 [message #327789 is a reply to message #327762] Thu, 01 May 2008 15:05 Go to previous messageGo to next message
if you REAAAALLLY miss it.. make sure there is a problem with your
configuration, like the recent ECF version conflict between P2 and ...
(I was trying to install EMF + some other features - the install led to
a second version of the ECF library to get installed and crash P2) with
3.4M6a, and the old UI is going to come back. ;-)
Laurent Mihalkovic, co-author SWT/JFace in Action (www.manning.com/scarpino)
Re: Where is "Manage Configuration" gone in 3.4M6 [message #327790 is a reply to message #327762] Thu, 01 May 2008 15:05 Go to previous messageGo to next message
Re: Where is "Manage Configuration" gone in 3.4M6 [message #327824 is a reply to message #327769] Sun, 04 May 2008 17:11 Go to previous messageGo to next message
However, it seems that p2 does not (yet?) support to have several
extension locations. Is that correct?
Patrick
Re: Where is "Manage Configuration" gone in 3.4M6 [message #327831 is a reply to message #327824] Mon, 05 May 2008 08:31 Go to previous message
It supports roughly equivalent functionality. Did you read the Getting
Started page?
Eric
Previous Topic:Create programmatically User Library
Next Topic:Showing CTabItem in CTabFolder
Current Time: Sat Jul 26 07:44:11 EDT 2025
Powered by FUDForum. Page generated in 0.04460 seconds
