Home » Eclipse Projects » Eclipse Platform » bin directory stays empty
bin directory stays empty [message #327724] |
Tue, 29 April 2008 11:52  |
I am running Eclipse 3.3.1.1 and have been an eclipse user since 2.x.
Over the years, the following problem has occasionally recurred: A
javanature project simply stops creating class files in the bin directory.
I make serious changes in the code that show no errors in the editor,
then save them but bin/ remains empty. The menu action Project > Clear
does not regenerate the .class files. Nothing I do causes class files to
appear in bin/. If I add my own ant build script to the project's list
of builders, it runs fine, but the standard builder (Java Builder), does
not generate classes in bin/.
Perhaps the builder is compiling and is putting the class files
somewhere other than bin/, or perhaps it is not even trying to compile.
I don not know.
My workaround is to create a new project, copy the source files into it,
and then delete the stuck project. It seems that the stuck project has
some state data that causes the problem, but I have not been able to
find anything in the .project, .classpath, and project prefs that seems
relevant.
Can anybody suggest what I might be doing to cause this problem ?
Bill
Re: bin directory stays empty [message #327726 is a reply to message #327724] |
Tue, 29 April 2008 11:49   |
Bill,
I've never seen this in the last 6 years of using it. Are there any
exceptions in the Error Log view when it's in this state? Is the output
folder still set to "bin" in the project's properties? Does doing
"Refresh" on the project help?
> directory.
> to appear in bin/. If I add my own ant build script to the project's
> list of builders, it runs fine, but the standard builder (Java
> Builder), does not generate classes in bin/.
> compile. I don not know.
> it, and then delete the stuck project. It seems that the stuck project
> has some state data that causes the problem, but I have not been able
> to find anything in the .project, .classpath, and project prefs that
> seems relevant.
> Bill
Re: bin directory stays empty [message #327728 is a reply to message #327726] |
Tue, 29 April 2008 12:34   |
Ed, Thks for yr reply.
No exceptions in Error Log View, Refresh does not help. Where is bin
specified in the project properties ? I've looked for it previously but
not found it.
Bill.
> Bill,
>> directory.
>> seems relevant.
>> Bill
Re: bin directory stays empty [message #327730 is a reply to message #327728] |
Tue, 29 April 2008 12:31   |
Bill,
Under Properties...->Java Build Path on the "Source" tab at the bottom.
> but not found it.
> Bill.
>> Bill,
>> output folder still set to "bin" in the project's properties? Does
>> doing "Refresh" on the project help?
>>> directory.
>>> editor, then save them but bin/ remains empty. The menu action
>>> Project > Clear does not regenerate the .class files. Nothing I do
>>> causes class files to appear in bin/. If I add my own ant build
>>> script to the project's list of builders, it runs fine, but the
>>> standard builder (Java Builder), does not generate classes in bin/.
>>> project has some state data that causes the problem, but I have not
>>> been able to find anything in the .project, .classpath, and project
>>> prefs that seems relevant.
>>> Bill
Re: bin directory stays empty [message #327733 is a reply to message #327730] |
Tue, 29 April 2008 14:20   |
Ed,
The bin/ directory spec points to ./bin in the project, as expected. But...
I have just finished my workaround (create a new project and copy in the
source), refactored the code a little, attached my builders, and
achieved the minor goal, blocked by the stuck project. Then, when I
re-opened the stuck project: it was stuck no more, and responded to a
trivial code change and save with a successful compile into bin/.
This is the reason I've held off reporting this problem - I have not
been able to create a stable test case, partly because I can work-around
the stuck project fairly quickly, and get on with my work. Here's what I
know so far:
Problem:
======= In the JDT, no class files are generated in the project's bin/
dir after a .java file change and save
While the problem lasts the following appear to be true:
- The .project file looks OK, just like compile-capable projects
- The .classpath file looks OK, no warnings, all libs, etc are as expected.
- The output dir is properly specified by an workspace-relative path in
the 'buildpath > source' page of the project prefs.
- user-defined ant script build, added to the project builders list, are
activated on change and save.of a .java file.
- I have not yet found a change to prefs/source/etc. that either caused
or cured the problem.
- Sometimes the project starts compiling again, the rest of the time it
doesn't.
I'm wondering if the problem is timestamp-related, caused by my
work-habits.
I often copy source files into projects from legacy source folders
outside Eclipse workspaces, using workstation tools. Perhaps incoming
timestamps are having some kind of adverse effect on the Java Builder
builder? The incoming files should have modification dates way before
the date on which they are copied. How could that be a problem ?
Anyway Ed, thanks for your questions and help. I'll keep an eye out for
this happening again, paying attention to my project-refactoring
activities outside eclipse, but for now I'm moving on. If I learn
anything, I'll repost to the group.
Bill.
Ed Merks wrote:
> Bill,
>> but not found it.
>> Bill.
>>> Bill,
>>>> directory.
>>>> Bill
Re: bin directory stays empty [message #327734 is a reply to message #327733] |
Tue, 29 April 2008 14:17   |
Bill,
Marco's theory sounds like a good one. I.e., does deleting the bin
folder itself fix the problem? As long as the source time stamps are in
the future, I don't imagine that should cause a problem...
Bill Winspur wrote:
> Ed,
> But...
> the source), refactored the code a little, attached my builders, and
> work-around the stuck project fairly quickly, and get on with my work.
> Here's what I know so far:
> Problem:
> expected.
> in the 'buildpath > source' page of the project prefs.
> are activated on change and save.of a .java file.
> caused or cured the problem.
> it doesn't.
> work-habits.
> for this happening again, paying attention to my project-refactoring
> Bill.
> Ed Merks wrote:
>> Bill,
>>> but not found it.
>>> Bill.
>>>> Bill,
>>>> any exceptions in the Error Log view when it's in this state? Is
>>>> the output folder still set to "bin" in the project's properties?
>>>> Does doing "Refresh" on the project help?
>>>>> directory.
>>>>> into it, and then delete the stuck project. It seems that the
>>>>> stuck project has some state data that causes the problem, but I
>>>>> have not been able to find anything in the .project, .classpath,
>>>>> and project prefs that seems relevant.
>>>>> Bill
Re: bin directory stays empty [message #327736 is a reply to message #327724] |
Tue, 29 April 2008 16:56   |
One possibility is that the project's build path has errors. There have
been occasional reports of Eclipse 3.3.x losing track of Classpath
Variables or User Libraries, so if you're project is using either of
those on its build path, that might be what is happening to you.
Even if you're not using CP Variables or a User Library, check that the
project's build path does not have any errors on any of the Source,
Libraries, etc. tabs - a project with build path problems will not
build, obviously.
Hope this helps,
Eric
Re: bin directory stays empty [message #327894 is a reply to message #327736] |
Wed, 07 May 2008 13:19  |
Thanks Eric,
I did find errors in my build path - caused by renaming something
outside the project - and when they were fixed the compiles to bin
happened normally.
Perhaps this is what I've been doing to cause the problem. Time will tell.
>> directory.
> build, obviously.
> Hope this helps,
> Eric
Current Time: Fri Jul 18 10:19:35 EDT 2025
Powered by FUDForum. Page generated in 0.04038 seconds
